Out of Town - Low Oil Pressure
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Out of Town - Low Oil Pressure in Past Cadillac Vehicle Discussion; I'm out of town with the car. About 300 miles from home and the low oil pressure - stop engine ...
    Slknyk is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Jan 2013
    49
    I'm out of town with the car. About 300 miles from home and the low oil pressure - stop engine message comes on. Silly question, but is there a "quick" check I can do to determine if it is simply the sending unit or something more serious. I checked the oil level. About a quart low. After restarting the car, the message didn't come back on. I'm a shade tree mechanic, but do not have any tools with me or access to any. Naturally I don't want to risk ruining the engine but I need to get home as well. Any advice? Thanks in advance.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The only test is an oil pressure test, with a pressure gauge.
    If the crank pulley/bolt has never been removed, I wouldn't worry about it.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,564
    Re: Out of Town - Low Oil Pressure
    NO - other than listen to the engine -
    but - 99.99% of the time it is a failed switch -
    Jan 2013
    49
    Thanks guys for the replies. Nothing has ever been done to the engine so nothing has ever been removed.
    Also, I pulled a newb mistake. Didn't post the codes.
    Only code is p1617 - low oil level switch.
    Perhaps the car set this message as a precaution to a possible low oil situation?
    It is running like a new car. Smooth as can be.
    Quote Originally Posted by Slknyk
    Edit - code showed as history.
    69
    82,163
    I am sure, being a shade tree this need not be said and I don't want to insult your intelligence, but don't confuse oil level with oil pressure.
    No. That's not how the system works. There is no relationship between level and pressure.
    Jan 2013
    49
    Ranger - your help would never insult me! I'm just trying to figure out the correlation between the low oil level history code and the low pressure message. I've driven it locally a couple of times and it runs as if it just rolled off of the line. I'm going to chance it i suppose. But man, I hate seeing such a message.
    c_d
    c_d is offline Cadillac Owners Fanatic
    Automobile(s): 06 Beetle 2.5L Manual, 08 Audi A3 TDI, 04 DeVille DTS
    Feb 2012
    SAT, BER
    152
    I once got the oil level message after having had the Deville jacked up fairly high up front. It was just a one-time fluke. I also got the oil pressure switch message. Funny, it only came up when going very slow or at a stop - as soon as I gave it a little gas, it just went away. It never came back after changing the oil pressure sending switch. AFAIK, if the message disappears after giving gas it's pretty much the switch giving up.
    69
    82,163
    Quote Originally Posted by Slknyk View Post
    There is no correlation. Two separate unrelated sensors.
  11. Remove Advertisements
