95 sedan de ville, 4.9, drives excellently until engine dies at low speeds,
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 95 sedan de ville, 4.9, drives excellently until engine dies at low speeds, in Past Cadillac Vehicle Discussion; then it restarts immediately. does this at low speeds, never above 30mph and usually when letting off gas at red ...
    baronneri is offline Cadillac Owners Member
    Automobile(s): 95 sedan deville, 98 devilled, 77 seville
    Aug 2013
    1
    then it restarts immediately. does this at low speeds, never above 30mph and usually when letting off gas at red light, turning a corner.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,846
    Re: 95 sedan de ville, 4.9, drives excellently until engine dies at low speeds,
    Quote Originally Posted by baronneri View Post
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    I suspect Idle Speed Control motor -
    Throttle Position Sensor -
    and/or dirty throttle body -
    69
    82,377
    Does this happen only with 1/4 tank of gas or less? The early '90's Devilles are known for tank baffles coming loose. Turn the corner and the fuel sloshes to one side, the pump sucks air and the engine stalls. There are 2 ways to fix it.
    1. Replace the tank.
    2. Keep it above 1/4 tank.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,491
    I thought the baffle problem was the earlier devilles? 95 has the same tank setup that the rest of the Devilles STS and Eldos had. But it does sound like it, unless it's just plain extremely low on gas.
    69
    82,377
    It WAS on the early Devilles, but I don't know exactly when that problem was fixed. I'm just taking a stab based on his symptoms.
  8. Remove Advertisements
