Results 1 to 6 of 6
Thread: I need help is identifying a wire coming out of my wiring harness
    jeepflambe is offline Cadillac Owners Member
    Automobile(s): 97 Deville Concours 1G6KF5496VU281009
    Jul 2011
    Miramichi NB Canada
    53
    31
    The grey wire is a cause for concern as I had to snip it off its mounting lug.
    I had to do so in order to get access to the lower water pump crossover bolts.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    Re: I need help is identifying a wire coming out of my wiring harness
    looks like a ground wire to me
    Caddy-EaRL's Avatar
    Caddy-EaRL is online now Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    716
    Why would you need help? You cut the wire, so now you need to repair it.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    I was thinking the same.
    Did you lose the other end of it?
  6. #5
    Jul 2011
    Miramichi NB Canada
    53
    31
    northstar 006.JPGThe other end was attached to the rear of the engine via a rusted on bolt. I could not remove the bolt yet absolutely needed the wire removed to bolt on my water pump crossover. If it is a ground I should be able to get away with relocating it as its original position is basically impossible to use.
    I just wanted to know if it was a "special" connection point. There is another bolt on the same location farther back toward the firewall I will try a lug and see if it can be reached and used. A better pic of where it goes is here.
  7. #6
    69
    82,262
    Sounds like a ground to me.
  • You may not post replies
