Newbie here want to learn about 2003 Deville IPC
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Newbie here want to learn about 2003 Deville IPC in Past Cadillac Vehicle Discussion; I have a 2003 Deville and the IPC is putting out codes like B1004, B1327, B1438 and B0429. I was ...
    Loumar1684 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Jun 2013
    68
    11
    ExclamationNewbie here want to learn about 2003 Deville IPC
    I have a 2003 Deville and the IPC is putting out codes like B1004, B1327, B1438 and B0429. I was told I need to have it rebuilt. So, first I need to figure out how to take it off the car and the I need to know where to send it.
    I have searched this forum, but I guess I have not used the correct words inthe search. So, I hope someone would reply and provide me with the info.
    Thanks
    Loumar
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Who told you you had to rebuild the IPC? Why?
    Codes are meaningless without their definitions, always include definitions when posting codes.
    I know 2 of those codes. B0429 is for a faulty rear vent blend door, VERY common.
    More importantly, B1327 indicates low voltage.
    Before worrying about the codes, what is your voltage readout with the engine OFF? Preferably after being off for at least 30 minutes?
    What is your voltage with the engine ON?
    SGWORLDWIDE Guest
    Re: Newbie here want to learn about 2003 Deville IPC
    HUH
    69
    82,163
    From what you said, I see no reason to replace the IPC.
    Boostmaster is offline Cadillac Owners Member
    Automobile(s): 03 Deville
    May 2013
    7
    Hey guys,
    Loumar is my father and he's never been on one of these car oriented web boards- having a hard time navigating all the info. (a little slack please)
    He is in another state so I am of limited assistance and since I am not familiar with these Caddy's I told him he should come here and see if he could find some answers.
    The car was taken to a shop because it kept giving the low coolant warning even after replacing the entire tank/sensor.
    Then it kicked out the low oil pressure code.
    He took it to some shop who scanned it and told him that a rebuild was necessary at $500 plus $85 hour labor.
    I've been doing a lot of reading on this but these Caddy's have so many computers and codes that it's a bit of a learning curve.
    Can you guys give us a little guidance?
    BTW, the Deville has around 146k on the clock.
    Located in FL
    Codes are as follows:
    B1004- Keep alive memory
    B-1327- Device Power Circuit Low
    B-1438- IPC High Voltage Output Overcurrent to IPM
    B-0429- Temperature Control #3 Rear Circuit Range/Performance
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    http://www.cadillacforums.com/forums/cadillac-deville-1985-2005-including-1985/138257-how-pull-codes-dtcs.html
    study that thread... if you haven't already
    get all the codes from the cluster using the onboard technique as instructed by the above thread
    make sure that you note history or current for each code
    and then follow the link in that thread to the OBDII codes page
    get the definitions for the codes you've got and then come back here and post the codes with their definitions (and history or current designation)
    once we have that we will have a more clearer picture of what is going on with the car
    as for the low coolant message... was the message false? coolant was not low but the message kept coming on?
    and if it was a false code and you did replace the whole coolant surge tank the low coolant message was still coming on falsely?
    May 2013
    7
    Rippy: Thanks for the link.
    Codes revisited:
    B-1438- IPC (Instrument Panel Cluster)High Voltage Output Overcurrent to IPM (Instrument Panel Module)
    To my knowledge, when the car went to the shop they claimed that they had to put in more coolant... Dad can chime in and clarify.
    I am also thinking that these were the only codes pulled by the shop. I did not see any mention of history or current in their paperwork.
    I can have him try and pull them himself and see what we get.
    In the meantime I will try and see what info I can find about these codes.
    Sep 2010
    East Boston MA.
    29
    26,325
    RE READ POST #2. You have 2 codes pointing to low voltage. Low voltage can cause false codes, warning messages, and other weird electrical problems. The codes can't be trusted before the voltage problem is taken care of.
    May 2013
    7
    I see. Good info.
    So we're just checking the voltage at the battery?
    I looked at numerous threads and it seemed bad batteries were an issue.
    Sep 2007
    Wilmington, NC
    13,986
    just turn the key on (engine off) and cycle through the dash display to show the voltage
    this is preferably done after the car has been off for over a half hour to let all the modules shut down fully
    alternatively you can use a digital volt meter to test the battery directly (with the battery cables disconnected)
    that gives a truer test of the battery but is not as easy and involves a tool that not everyone has
    after you get your unloaded/off voltage turn the engine on and see what it has for voltage while running
    report back here your findings
    also losing coolant is not a good sign if there are no visible signs of external leaks
    let's not go there yet though ... it may be premature to speculate the worst
    May 2013
    7
    The battery will be checked shortly.
    When I was down there we pulled the reservoir and I pulled the sensor. It was mangled. I tried to simply order the sensor but could not find it and it looked as if the reservoir cap was a little worn so it was just easier to replace the whole unit. I think it may have just been a little low on coolant.
    I've checked the oil and looked for signs of bad head gasket/cracked head... Did not see anything to warrant concern.
    For more accurate details dad will need to respond.
    Jun 2013
    68
    11
    REPLY::
    Don't have a digital meter.. but these are the reading I was able to get...Car had been aprked for 24 hrs before the readings.
    With Battery connected 13.5 DC volts, disconnected 12.5
    When I cycled thru the dash display (eng off)
    Feature programmimg Off .. Don't know how to turn it on
    RF Tire PSI ? ( no reading) Acutal reading was 33.5
    volts 12.3 OK
    When I cycled thru the dash display (eng On)
    Feature programming OFF .. Don't know how to turn it on
    1175 RPM Tach
    RF tire PSI ? (no reading) Actual reading was 33.5
    volts 14.7
    The coolant problem has been resolved... Apparently I was filling the reservoir tank to the wrong full mark. Once the garage filled it to the correct level the warnig has not returned.
    There were no oil leak indications under the car nor around the oil sensor.
    Thanks!!
    Sep 2007
    Wilmington, NC
    13,986
    that all sounds normal and good
    so the CURRENT codes are the only problems
    doesn't look like you'll need to rebuild your IPC
  16. #14
    69
    82,163
    Quote Originally Posted by Loumar1684 View Post
    Thanks!!
    The correct level is 1/2 full (no more than 2/3).
    Quote Originally Posted by Boostmaster View Post
    Rebuild what, the engine or the IPC? If he meant the engine, run far and fast from that shop.
  17. #15
    Jun 2013
    68
    11
    OK, Great!!
    So, how do I correct the CURRENT problems? Do I need a new battery?
    Please advise...
    Thanks
    Not the engine, but the IPC.
    RippyPartsDept believes the IPC is OK and that I am having problems with the CURRENT I reported last night.
    So, my next step it to correct the CURRENT problems.. any ideas??
  18. Remove Advertisements
