Newbie here want to learn about 2003 Deville IPC - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Newbie here want to learn about 2003 Deville IPC in Past Cadillac Vehicle Discussion; If the car runs and drives normally with no driveability problems, and your father isn't antsy about repairing the mode ...
  1. #16
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    Re: Newbie here want to learn about 2003 Deville IPC
    If the car runs and drives normally with no driveability problems, and your father isn't antsy about repairing the mode door for the rear seat HVAC console, the other codes are inconsequential. Drive the car. The engine OFF and idling voltages are dead on target. DIC access to Feature Programming (if available on the base Deville) is thoroughly covered in the Owner's Manual.
  2. #17
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    by CURRENT i mean present/now not electrical current
    you listed the codes that you got from the dash but you never said if they were CURRENT or HISTORY
    just a thought that maybe there was some miscommunication there and want to make sure everyone's on the same page
    and Sub is correct about reading up on the Feature Programming in the owners manual ... should cover pretty much all you will need
  3. #18
    Loumar1684 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Jun 2013
    68
    11
    Quote Originally Posted by Submariner409 View Post
    Don't know if the codes I was given are current or history... willl check into this.
    Will also check on Feature Programming" and see what I get.
    Much appreciate your assistance
    Thanks
  5. #19
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    RE READ POST #2. You have 2 codes pointing to low voltage. Low voltage can cause false codes, warning messages, and other weird electrical problems. The codes can't be trusted before the voltage problem is taken care of.
  6. #20
    Sep 2007
    Wilmington, NC
    13,986
    Is there an echo in here?
  7. #21
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by RippyPartsDept
  8. #22
    68
    81,922
    Not anymore.
  9. #23
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    Not anymore.
  10. #24
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by basscatt
    I missed something, didn't I ?
  11. #25
    Jun 2013
    68
    11
    A/C Motor blower operates intermittently 2003 Deville
    I have followed your advise and decided to drive the car with these not so serious warnigs... I'm keeping an eye on all so called discrepancies for now...
    But new problem now; this car has 145K miles and of course some things will start to fail. The AC blower motor is starting to go. It operates intermittently, the AC shop wants $500 to replace the blower motor and the resistor.
    So, I can it both items for under $50.00 at Autozone... or do I need get it from the dealer (much more $$)
    Would anyone be able to direct me to a video or link where I can see the steps or gt an idea of what I'm facing..
  12. #26
    68
    81,922
    Replacing the blower is not too difficult, but stay out of AutoZone. You might check the ground in the passengers side kick panel first. If that's not the problem and you are handy, you might try disassembling the blower and look for a loose wire. The other option is go to Rockauto and order one of their blowers. www.rockauto.com
  13. #27
    Jun 2013
    68
    11
    Will do... Thanks
  14. #28
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    28
    538
    When my 03 DTS was leaking coolant massively it was the water pump. Replaced it and surge cap and my 03 still rides like practically new still quiet when on. It has 154k miles.. I feel like these cars can reach the 200k mark.. tryna make it there so I can by the 2015 flagship when it hits!!!
  15. #29
    68
    81,922
    200k? They can do that with ease. Here are a few examples, but look at post #366.
    http://www.cadillacforums.com/forums...ho-can-25.html
  16. Remove Advertisements
