Results 1 to 5 of 5
Thread: 94 concours deville idling issue....
    Apr 2011
    38
    I've been having this issue with my caddy where the car is idling Up,,,,,Down,,,,,Up,,,,,Down. And just recently now its (the car) dieing out on me when its idling only...it starts up fine and drives fine....just like I said the problem appears to be idling related....any ideas would be great. Thanks.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Have you pulled the codes?
    When was the TB last cleaned?
    Apr 2011
    38
    Are you referring to throttle body?....no I haven't had it cleaned.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: 94 concours deville idling issue....
    like MC already suggested -
    check and clean the throttle body -
    don't forget the Idle Air Control valve -
    and check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  6. #5
    69
    82,278
    Quote Originally Posted by iluvcaddys View Post
    That would be a good place to start and then check for vacuum leaks.
  • You may not post replies
