water in trunk
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, water in trunk in Past Cadillac Vehicle Discussion; Hi guys,messin round with the car today,found water in lower trunk! My pull down isnt working bit seems to be ...
    Joe2thabone is offline Cadillac Owners Member
    Automobile(s): 84 seville,96 deville
    May 2013
    Jacksonville,Fl.
    54
    33
    water in trunk
    Hi guys,messin round with the car today,found water in lower trunk! My pull down isnt working bit seems to be in the full down position.I noticed it is unplugged so gonna clean contacts,check fuses etc.My question is trying to determine if I need new trunk seals or simply(?) get the pull down working? Also is there a weep hole somewhere in the trunk that may be blocked?? Awful smelly & damp in there!
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: water in trunk
    pull the trunk liner out. It needs to dry anyway.
    Look for water stains to indicate where the water is traveling.
    I have one all the seam sealer in the rear redone.
    I have two out here that are leaking from rear window seal lower left corner area.
    May 2013
    Jacksonville,Fl.
    54
    33
    Good idea,thanks!
