2004 DTS Hard Shifting - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 DTS Hard Shifting in Past Cadillac Vehicle Discussion; Would having the transmission fluid changed and replaced to the proper levels at a gm dealership with the current dexron ...
  1. #16
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    Would having the transmission fluid changed and replaced to the proper levels at a gm dealership with the current dexron help at all? An if the cooler is bad is that something we could do ourselves?
  2. #17
    JuniDTS is offline Cadillac Owners Member
    Automobile(s): 2004 DTS
    Aug 2013
    11
    This is with the engine running cold it's pretty high
    Sent from AutoGuide.com Free App
  3. #18
    Aug 2013
    11
    This was with the engine off/cold first idk if you can see but the tip has fluid on it. Would to much fluid make it shift hard? If so why doesn't it do it every time I drive the car? Idk if it matters but the coolant level in the coolant tank looks good if it was leaking into the Tranny wouldn't the level be lower?
  5. #19
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,574
    Re: 2004 DTS Hard Shifting
    It's still a tad high - with the engine running at idle see if you can use the ol' turkey baster and rubber tube trick to suck out another pint.
    BUT - that little bit of overfill should not cause weird transmission operation - "hard shift from P" - Is this with the engine still at the 1200 rpm or the 950 rpm fast idle sequence ?
    Transmission oil cooler in these cars = whole new radiator.
  6. #20
    Aug 2013
    11
    Doesn't shift hard out of park it only shifts hard when driving down the road I notice it fr
    1st into 2nd and beyond
  7. #21
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Could be a sticky pressure solenoid.
  8. Remove Advertisements
