Bulb type for front turn signal?
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Bulb type for front turn signal? in Past Cadillac Vehicle Discussion; Im pretty sure there 3157 but is there different types of 3157 bulbs i wanted to put silverstars in them ...
    SGWORLDWIDE Guest
    Im pretty sure there 3157 but is there different types of 3157 bulbs i wanted to put silverstars in them and the socket is a round socket much different from the wedge style socket in the rear back up bulbs that i put 3157 silverstars in?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A round socket bulb would probably be a 1157. 3157 is a dual diligent wedge base.
    SGWORLDWIDE Guest
    Re: Bulb type for front turn signal?
    Hey moist how u been? I figured can any one who has a deville confirm bulb type? its the only bulbs i havent changed to silverstars because i dont know what type it is and sylvania's site is wrong saying its a 3157
    Sep 2010
    East Boston MA.
    29
    26,325
    Been ok. Thanks.
    1157 round base bulbs are mostly found in older vehicles. Are you sure you're calling it the right thing?
    Edit: Actually just found a video of a turn signal bulb change for '00-'05 Devilles. It's definitely a wedge type bulb
    SGWORLDWIDE Guest
    the rear reverse lights are 3157 wedge unless your referring to the side marker bulbs which are small 194 wedge aswell as the parking lights in the headlight the main turn signal in the headlight housing are round with a round socket i think ur right there 1157 want to order but need to confirm
    U know what moist? i just thought of somthing on my old headlamps the bulb and socket where round but those headlamps where aftermarket junk i just bought new oem Gm headlamps to go with my restore job on her i saw the video aswell but the after market ones where not a 3157 wedge i got to check my new headlamps
    and i just noticed somthing else that deville in the video those side markers looked like 3157's but my side markers take 194 small wedge and i can confirm that mmmmh this is weird
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,473
    Quote Originally Posted by SGWORLDWIDE View Post
    according to the 2004 Deville Owners Manual - page 5-58 -
    BOTH the front turn signal - and cornering lamps are 3157 -
    SGWORLDWIDE Guest
    just checked em today the turn signals on GM OEM lamps are 3157 the aftermarker ones i had where not they where 1157 weird BUT the side markers are 194 small wedge not 3157 even sylvanias bulb finder says there 194 mabe GM make a typo hhmmmmmhh
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,473
    correct -
    the side markers are the small amber colored light behind the amber reflector -
    on the side of the headlight -
    all they do is illuminate whenever the parking lights - or headlights are on -
    they do not blink/flash - or anything else -
    the cornering lights are the clear 3157 bulbs behind the big clear lens on the side -
    they illuminate with the turnsignal - but do not flash -
  11. Remove Advertisements
