Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: trunk popper not working
03-17-05, 01:38 AM
| | Cadillac Owners Member | | Join Date: Feb 2005 Location: baltimore Age: 25 | | | trunk popper not working i have an 87 deville and my trunk release button does not work also the automated trunk closing mechanism in the trunk does not automatically go up there for i have to pull it up then the trunk will close automatically but this should come up when i open the trunk automatilcally i should not have to manually do anything. |
03-17-05, 09:06 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1999 DeVille, 1988 DeVille | | Join Date: Jul 2004 Location: Northern Virginia Age: 67 | | | Re: trunk popper not working I believe your '87 is like my '88...the latch release solenoid is mounted on the deck lid and the latch motor and mechanism is mounted in the trunk, right? Check the wiring going to the solenoid on the deck lid to be sure it is solidly connected to the solenoid. A loose connection here would keep you from being able to open the trunk with the button. Opening it with your key does not require the solenoid to activate. If the wiring looks ok, the solenoid and/or release mechanism may be bad.
Your second problem, the "pull up on the latch" part, sounds like the trunk lid retractor mechanism (the part with the latch you are pulling up on) may need replacing. There is a metal rod running across the inside front lip of your trunk...it has exposed, slightly bent ends to allow you to tie the trunk closed when carrying bulky items. Be sure that the middle of this rod is not touching the trunk retractor mechanism's metal body...the retractor mechanisim is insulated from ground with a plastic mounting and needs to be kept that way. Carefully bend the rod away from the trunk retractor mechanism's metal body, if necessary, but don't put any stress on the retractor mounting as you can easily break the plastic insulator.
There should be a flexible metal contact strip on the top left side of the mechanism that will touch the deck lid when you are closing it. This will provide a ground to allow the mechanism to pull the trunk closed.
After checking out the above, if it still doesn't automatically extend the latch ring when you open the trunk (without having to pull on the latch), you might shop around for a used one online (they are really expensive at the dealer). If the latch solenoid on the deck lid is bad too, you should get both parts at the same time. Just be sure you specify exactly which caddy you have, to the used parts dealer as these parts vary greatly from Caddy to Caddy.
Kind of a long answer but, I own three DeVilles and had to fix two of them with the same problems you have. Good luck! |
12-13-08, 12:29 AM
| | Cadillac Owners Fanatic Cadillac(s): 91 SDV, 01 SLS | | Join Date: Aug 2008 Location: Ozarks | | | Re: trunk popper not working hey, where or what are you referring to as the "deck lid"? Thanks, |
12-13-08, 01:21 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: trunk popper not working The "deck lid" is the trunk door. |
12-13-08, 05:02 PM
| | Cadillac Owners Fanatic Cadillac(s): 91 SDV, 01 SLS | | Join Date: Aug 2008 Location: Ozarks | | | Re: trunk popper not working thanks ranger, i thought that was most likely it after i asked...Dooah, so I looked at it today and saw where the power line goes to the trunk latch, there is a connector there, is this the area of the probable issue? |
12-13-08, 07:13 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: trunk popper not working Sure there is a connector there. Don't know if that is where your problem is because we don't know WHAT your problem is. |
12-13-08, 08:37 PM
| | Cadillac Owners Fanatic Cadillac(s): 91 SDV, 01 SLS | | Join Date: Aug 2008 Location: Ozarks | | | Re: trunk popper not working I appologize, I think i have started two threads, Ranger, I have been reading this forum for several hours over the last few weeks. (I get overwhelmed)...I have slowly began to see how to find info that I need. Your username has been in alot of them, and that submarine guy  and you seem to know yo stuff, I really appreciate this site and you all.
I have two caddys a 01 sls and a 91 sdv, sometimes I find a older post and have responded, then I thought, I should have just asked on a new post, I try to find out what I need from the historical posts, I know some of the issues have been posted to death. so...what I had asked on the other post was help with the "trunk release button" located in the glove box, my trunk closing motor works fine if that matters? I doubt it. this is on the 91 sdv no keyless entry, (no fuel door release button in G/Box), so I was told to check the solinoid on deck lid...so I am thinking that this is where to start to trouble shoot, even though I don't know how to check a solinoid. Ha, I try to be a do it my selfer.
Thanks again |
12-13-08, 09:42 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: trunk popper not working Yeah, you're better off with a new thread. I seem to recall responding to it. I'll continue any thought I have there. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
