Seat stuck all the way back. 97 Deville
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Jfarr
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Seat stuck all the way back. 97 Deville in Past Cadillac Vehicle Discussion; As the title says, need to take the drivers seat out but can't access the rear bolts because the seat ...
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    As the title says, need to take the drivers seat out but can't access the rear bolts because the seat won't go forward. Is there a way I can manually move the seat forward or at least some way I can remove the rear bolts?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Not fun.
    You have to remove the upholstery from the seat bottom, disconnect the drive cables from the motor, and turn them both a little bit at a time.
    Jun 2013
    65
    Re: Seat stuck all the way back. 97 Deville
    Problem solved
    Turned out to be the switch. The back of the switch had come loose and allowed the contacts to separate. A little J.B. Weld and "like new".
    CadillacLuke24 likes this.
