Rough idle
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Rough idle in Past Cadillac Vehicle Discussion; Ok so the head gasket job went fine. Car runs fine. Has rough idle though. Cleaned TB. Swapped out plugs ...
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    737
    Ok so the head gasket job went fine. Car runs fine. Has rough idle though. Cleaned TB. Swapped out plugs and boots at HG job, swapped out coil cassettes with known good ones on hand. Wondering if the injectors got slightly clogged while car sat about 8 months. Idles at 750 and its fine until it warms up and idle gets rougher the hotter it gets. Yet take the idle up to 1000 and its smooth as silk. Racking my brain here. This mornin I ran some top engine clean through the intake and am letting it set all day. Hoping the nasty ass valves get cleaned up a bit and will fix this rough idle.
    hendershot15 is offline Cadillac Owners Member
    Automobile(s): 2004 deville
    Aug 2013
    30
    9
    Re: Rough idle
    check your IAC valve and clean the throttle body. I had a similar problem and replaced the IAC valve and problem was gone. I don't know if this helps but you can try it. You can remove the IAC valve and spray some cleaner into it and see if that improves anything.
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    51
    737
    Guess its possible, never really seen an iac valve cause a rough idle, usually makes the engine stall. Already cleaned the TB.
    Aug 2013
    30
    9
    Re: Rough idle
    all I am saying is to check it. worked for me... disclaimer: I am no car expert in any means
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,847
    Re: Rough idle
    Quote Originally Posted by Caddy-EaRL View Post
    OK - since you've around the block more than once -
    I won't ask if the have checked for codes -
    I will assume you have - and there are none -
    it sure sounds like a vacuum leak to me -
    runs rich at cold start - so idle is smooth -
    leans out as it warms up - and runs rough -
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    51
    737
    Well it seems like the top engine clean has helped it. He drove it home and will let me know tomorrow.
    tatteddaddy87 is offline Cadillac Owners Member
    Aug 2013
    1
    Did the top engine clean work in the long run? I am wondering because i have a 99 eldorado with the same problem .i have replaced the intake manifold and the fuel pressure regulator
    JDemoney is offline Cadillac Owners Member
    Automobile(s): 2002 DeVille
    Aug 2013
    Box Elder, SD
    88
    The IAC can cause rough idles. If you don't want to replace it, remove it and hit it good with some brake parts cleaner. Make sure it's COMPLETELY dry prior to reinstall..
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Re: Rough idle
    .......... and clean out the throttlebody IAC bore with TB cleaner and a fuzzy pipe cleaner from a craft store. That black top hat plunger on the IAC motor gets fluffed up, too.
  12. Remove Advertisements
