2001 DeVille Wont shift out of park
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 DeVille Wont shift out of park in Past Cadillac Vehicle Discussion; have a 01' DeVille the battery died. a couple of days later I jump the car and it started up ...
    rberteo is offline Cadillac Owners Member
    Automobile(s): SLS 95'
    Apr 2013
    4
    have a 01' DeVille the battery died. a couple of days later I jump the car and it started up fine but when I tried to shift out of park the lever moves but the gear doesn't engage. I read on forums about a "neutral shift lock" or "orange Button" under the ashtray but I don't see anything but carpet... Where is the location for this please help.
    68
    81,926
    Re: 2001 DeVille Wont shift out of park
    I think the orange release button is only on the floor shift models. You are holding your foot on the brake, aren't you? That should electronically engage the shift interlock solenoid.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by rberteo View Post
    so you are saying you can start the car -
    and move the shift lever to Drive -
    but the car doesn't move?
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by basscatt View Post
    That's what I got out of it, too.
    Coincidental but bad cable, linkage or broken trans. (if that's the case)
    Apr 2013
    4
    I start the car and when I engage in any gear the gear doesn't engage. like if is stayed on neautral the whole time... I kept hearing about the neutral safety switch. where would that be located in this model car
    also when I move the lever it just stays on Park... and the emergency brake wont disengage unless I do it manually.
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    484
    Did a little searching and found several people with similar problem with 2000-05 Seville and sevilles. Internal mode switch also plastic clip on rod from aims to the parking pawl broken. There cars indicated computer thought they were in drive or 2nd gear.
    http://www.cadillacforums.com/forums...-says-its.html
    68
    81,926
    Check to be sure that the shift linkage is still connected at both ends.
    Feb 2012
    NYC
    49
    1,948
    Doesn't the shifter move a little easier than usual?
    I can almost feel it from here.
    Again-
    Apr 2013
    4
    the linkage is connected on both sides... I can start the car but when I shift gear the digital dash stays in Park.. and it doesn't engage in any gears and the emergency break doesn't disengage( I do it manually).. and the shift feels the same.
    the car used to work fine with no problems.. one time the battery died and stay dead for a week.. I needed to jump start the car but I had no room, so I put it in Neutral and push it back so I can make room to start it.. I jump start it and after that the car never worked
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Did you force it to neutral when you moved it with no battery power?
    Feb 2012
    NYC
    49
    1,948
    If you move the shifter out of park with the car not running, can you push the car?
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Yes, but in order to bypass the shift lock, the key needs to be on "accessory" (between off/lock and on/run). Otherwise it'll break when you force it. Normally having "key-on" and stepping on the brake will let you shift, but with no battery power, this might not be possible.
    Apr 2013
    4
    when I did push the car I turn the key,press the break and it let me put it in neutral that's how it was able to roll...
    I don't think I can push it when in park...
    I hear a small click when I try to engage in a gear but the digital dash stays in Park
  16. #14
    Feb 2012
    NYC
    49
    1,948
    If the trans is coming out of park, but there is no engagement and indicator reads park, both the IMS & manual valve have become disconnected inside lower pan.
  17. #15
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Make sure your range selector cable terminal(1) is correctly connected to the trans range selector lever(2). The trans range selector lever should move with your range selection with the gear shift.
  18. Remove Advertisements
