I hate....
Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, I hate.... in Past Cadillac Vehicle Discussion; ...this car! "low coolant" message again..... I think it is time to enter the thing in the demolition derby!...
    Slipgate is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Deville
    Jul 2009
    48
    710
    I hate....
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: I hate....
    Quote Originally Posted by Slipgate View Post
    she is going to HEAR you -
    - HOPEFULLY - she didn't - and it's not too late -
    here is what you need to do - IMMEDIATELY -
    FACE NORTH - and BOW - - to the NORTHSTAR GODS - 3 TIMES -
    Open the car's hood - and stroke the beauty cover - -
    while repeating - 3 times -
    immediately after this ceremony - do a cooling system pressure test -
    IF the NORTHSTAR GODS accept your apology -
    you will see the easy to repair leak -
    if you do - repeat - 3 times -
    and fix the leak -
    if NOT -
    mc_marto and Mojo88 like this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    Re: I hate....
    Careful - even if you are 4 Manhattans over the top ...........
    c_d
    c_d is offline Cadillac Owners Fanatic
    Automobile(s): 06 Beetle 2.5L Manual, 08 Audi A3 TDI, 04 DeVille DTS
    Feb 2012
    SAT, BER
    152
    Re: I hate....
    Who? Bass or Slip?
    Slknyk is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Jan 2013
    49
    Re: I hate....
    LOL at Sub; I was thinking the same thing!
    Basscat deserves the "Best Use of Emoticons in a post EVER Oscar". Awesome!
    Jul 2009
    48
    710
    Re: I hate....
    lol - awesome! I'll try that tonight for sure.
    The cooling system will maintain pressure overnight. I park it at 4:30pm and the next morning it will still have decent pressure in the system. Just tired of chasing leaks. I put about 1/2 gallon in it last night. First time I had to add anything since the radiator was replaced a few weeks ago.
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    28
    538
    When this happened to me I had to get new water pump, thermostat, coolant resivor cap
    Feb 2006
    55,904
    Re: I hate....
    Quote Originally Posted by Slknyk View Post
    Nothing to do with basscatt - there was some prior salty language edited out that few people saw ...............
    c_d
    Feb 2012
    SAT, BER
    152
    Re: I hate....
    Quote Originally Posted by DSNCB919 View Post
    Funny how significant those caps are. How did you determine that you needed a new water pump?
    @Bass: I'd recommend one adjustment to your procedure of pleasing the N* gods. Anyone not named bass, Sub, Ranger or Moist (and some others I surely forgot) cannot open the hood and stroke the beauty cover since due to constant work on the car it's i the trunk. I cannot afford the extra 30 seconds to take it off :-)
    Anyway, this might also be a good place to remind people that the plastic covers (top and bottom) of the radiator and fans are in fact *not* beauty covers but play a role in shaping and directing air flow.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    64
    344
    Re: I hate....
    You need to borrow a good pressure tester to create sufficient pressure for a reliable test. I have a top-of-the-line Stant tester that I bought maybe 30 years ago and it still works like new. You can likely borrow something similar at Autozone (or elsewhere).
    Once you have a good tester in hand, pressurize the system up to limit stated on the cap, which is about 18 psi. Then watch and wait. Keep a flashlight handy. You'll eventually see some dripping, unless it's head gasket, which would leak inside engine........
    "Radiator was replaced a few weeks ago" definitely caught my attention. Could easily be a defective radiator or bad hose connection.
    Good luck
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: I hate....
    maybe it just took this long to purge all the air from the system -
    after the radiator replacement -
    if the system maintains pressure overnight - something is wrong -
    the system only builds pressure because the coolant expands as it gets hot -
    when the system cools back down - the coolant contracts -
    and the pressure is gone -
    if your system is still under pressure 12+ hours later -
    and the engine/coolant is cold -
    that pressure is NOT coming from the normal coolant expansion -
    and the ONLY other thing that can pressurize the cooling system -
    is EXHAUST GAS - as in a leaking head gasket -
    sounds like you should do a BLOCK TEST -
    Mojo88's Avatar
    Dec 2011
    Newport, RI
    64
    344
    Re: I hate....
    Quote Originally Posted by basscatt View Post
    after the radiator replacement - ....
    Yeah, ^^^^^^^^^^ this is quite possibly the answer.
    Jul 2009
    48
    710
    Re: I hate....
    Quote Originally Posted by Mojo88 View Post
    This though had crossed my mine. I will keep an eye on the level. And even if the HG was blown, I don't think it would keep pressurizing the system all night.
  16. Remove Advertisements
