1995 deville w 4.9L 4T60E trans downshifting problems
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1995 deville w 4.9L 4T60E trans downshifting problems in Past Cadillac Vehicle Discussion; I have a 1995 Deville, 150k miles just started having downshifting issues with the transmission. When downshifting from 2nd to ...
    red_ghost is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Deville, 1995 Deville
    Nov 2005
    Green Bay Wi
    29
    220
    I have a 1995 Deville, 150k miles just started having downshifting issues with the transmission. When downshifting from 2nd to 1st, at around 15-11 mph it will clunk extremely hard causing the vehicle to shake. Transmission fluid has been changed. There were no metal shavings in the pan. There are no ODBI codes for this. Any ideas?
    mc_marto's Avatar
    mc_marto is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Cadillac Sedan deVille
    Aug 2011
    Fort Smith, AR
    27
    529
    Re: 1995 deville w 4.9L 4T60E trans downshifting problems
    Check your vacuum modulator, and the vacuum line going to it. If the line and the hose fittings are ok, unplug it and spin it so the modulator points down. If anything leaks out of the port the modulator is bad.
