'99 engine stumble
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '99 engine stumble in Past Cadillac Vehicle Discussion; Just bought a beautiful pearl white Deville with unknown history with a nasty engine stumble; not a 'miss', but a ...
    Harry Yarnell is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    73
    847
    '99 engine stumble
    Just bought a beautiful pearl white Deville with unknown history with a nasty engine stumble; not a 'miss', but a chuggle just short of stalling while driving. In neutral, it throttles up just fine, and it starts instantly. When I say it's not a 'miss', I mean the stumble is erratic, as a miss is cyclical. A code 131( O2 sensor) is set, but this all is happening before it goes closed loop, so I don't think that comes into play. Here's what I've done: changed fuel filter, fuel pressure is 46#, glass beaded all 8 plugs, though they looked fine, measured resistance of all 8 wires; all within spec, swapped out ignition module. No change. Thinking of swapping PCM, but isn't there some reprograming required to do this?...and what is it? Anyone got some other ideas?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,283
    Re: '99 engine stumble
    Clean the coils, connectors, contacts, ICM and the ICM ground cable terminals. How old are the plug wires ? Time for a new AC Delco wireset. Use the pre-2000 plug wire diagram in my albums to make sure the proper coil tower is connected to the proper plug.
    Dec 2004
    perryman, MD
    73
    847
    As a follow up to this issue, seems it was TWO problems; one may have caused the other. Glass beaded the existing plugs (they looked good before). no help. REPLACED the plugs with new platinum AC's, and the miss (chuggle) was sorta gone, but it had no power; the more you gave it throttle , the more it bogged down, Shifting was also late. Suspect a clogged cat. Up on the lift, and you couldn't get near the cat, as it was so hot. Disconnected the four nuts holding the cat to the header pipe, and a test drive showed it would go like a scalded cat (pun intended). Oh, BTW, the dealer wants $100 to reprogram a replacement computer. As to the code 131, they mention a O2 sensor lean condition in bank 1. Which is bank 1? Front or rear?
    Feb 2006
    56,283
    Eastern Catalytic drop-in and a pipe clamp.
    68
    82,084
    Bank 1 is the rear bank.
    Dec 2004
    perryman, MD
    73
    847
    This clogged cat reminds me of a similar situation years ago with a '74 Cadillac hearse. This vehicle wouldn't get out of its own way, the shifts were late and there was this wheezing sound coming from the exhaust. Back then GM was using a double walled exhaust pipe on some models , why, I don't know, but the inner pipe (or wall) had pulled away from the outer pipe and coiled up like a pretzel inside, effectively closing it off. I don't remember how I discovered that, but I cut out that section of pipe for show and tell...
  9. Remove Advertisements
