A tap tap tapping-Tensioner?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, A tap tap tapping-Tensioner? in Past Cadillac Vehicle Discussion; click click click click click... Frequency increases with engine speed. Cannot hear it inside the cabin. Sounds like it's from ...
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    click click click click click... Frequency increases with engine speed. Cannot hear it inside the cabin. Sounds like it's from the tensioner or idler pulley area. Don't think it's the new compressor or alternator.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    64
    344
    Re: A tap tap tapping-Tensioner?
    Here's a thread where I recently had same question. 'Ranger' offered tips on checking tensioners.
    http://www.cadillacforums.com/forums...-any-easy.html
    Good luck!
    68
    81,922
    Kind of sounds like one of the pulley bearings. Try what I suggested in the link. That should narrow it down.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    and I wouldn't even drive it around the block -
    until you identify that noise -
    if it is the idler pulley - it could go at any second -
    and leave you stranded -
    Jun 2013
    65
    Used the 1/2" pull bar to remove the tension from the belt, clicking went away.
    Removed the tensioner, other than a little slop, bearing felt fine. Idler pulley felt smooth albeit a little sloppy.
    Noticed the drive pulley (crankshaft) does not run true, probably 1mm runout (+/-).
    Ordered new belt, idler and tensioner.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Dad has serp belt wrench kit. Have never used it till last week. Bar has a hex cutout and all the sockets are hex drive. I looked at it for a few minutes and thought my eyes were playing tricks. Hex sockets sure but hex drive? 60 deg rotation angle for bar. I used a 16mm socket on a external Torx head bolt. I did not have a E20 socket in my kit and the 16mm fit perfect.
    68
    81,922
    It could be the idler as well as the tensioner. That's where a stethoscope would come in handy to locate the culprit. If the tensioner doesn't so it, you'll know where to look next.
    Jun 2013
    65
    Going to replace both as well as the belt.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    ANY "slop" - any - in a tensioner or idler pulley is NOT GOOD - those should feel smooth and "viscous" when turned by hand.
    Just for grins and kicks, ask to see a new one at a parts store - feel the difference between it and yours.
    Jun 2013
    65
    Quote Originally Posted by Submariner409 View Post
    Heh, not one anywhere in the area. Ordered the parts from Summit.
    Jun 2013
    65
    Belt, tensioner and idler replaced, noise gone.
    Feb 2006
    55,904
    Thanks for the comeback - Now ..... Did we talk about the water pump drive belt tensioner pulley ???????
    Jun 2013
    65
    Ordered a new wp tensioner pulley after I replaced the belt. The bearing is probably OK but I feel the lube has turned into something other than grease.
    I feel like if I keep throwing enough parts at the old girl the head gasket gods will be pleased.
  16. #14
    Jun 2013
    65
    Noise has re-appeared. Compressor clutch bearing. Hammers when clutch is disengaged, quiet when the compressor is running. Still cooling great!
    FYI, AC parts are from Arizona Mobile Air. GPD manufacturer (China). Condensor didn't fit, had to return for refund. Compressor will be replaced under warranty (Do I want another Chinese compressor?)
  17. #15
    Harry Yarnell is online now Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    72
    823
    I have used Chinese compressors for years on maybe 7 cars with no trouble. They seem to be well made.
  18. Remove Advertisements
