Results 1 to 10 of 10
Thread: Maybe a new SRS unit?
    dommi.b is offline Cadillac Owners Member
    Automobile(s): 1995 Deville Base 4.9L
    Sep 2012
    Elmhurst, IL
    15
    Hi guys! My 1995 Deville had been flooded a few years back, and adding insult to injury set off both airbags (SRS unit is under driver seat).
    I have since then replaced the steering wheel airbag and fixed my dash the best I could but haven't plugged the wheel back in because I don't know if it would set off the new one it is also sending a bunch of codes most starting with R0 and when the key is in the on position it will continuously say check airbag system, traction control is turned off and change engine oil (It won't let me clear the change oil notification)... It's all quite annoying. How likely would it be that installing a new SRS unit make it okay to plug it all back in and most likely fix my issues?
    I'd like to feel safe in my car again!
    Thanks!
    EDIT
    trouble codes
    R016 History .................................... Passenger Initiator Circuit Resistance Low
    R017 Current .............................................. Passenger Initiator Circuit Open
    R024 History ................................................. Initiator Circuit Voltage Low
    R025 History........................................... Initiator Circuit Short to Ignition
    R026 Current........................................... ...... Driver Initiator Circuit Open
    R036 History....................................... Passenger Loop Energy Reserve Feed Open
    R051 Current........................................... ....... ...... Frontal Crash Detected
    R052 Current........................................... ....... .............. Data Area Full
    R061 History........................................... ...... SIR Indicator Circuit Failure
    R062 History....................................... Redundant SIR Indicator Circuit Failure
    R071 Current............................... Internal Diagnostic Energy Reserve Module Fault
    T061 Current........................................... ....... .... Motor Pump Circuit Fault
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    What codes are you getting? (Don't forget to include their definitions)
    Sep 2012
    Elmhurst, IL
    15
    Re: Maybe a new SRS unit?
    Oh boy... there's so many... that's a mission. I'll go get them all as soon as I can.
    trouble codes
  5. #4
    Sep 2010
    East Boston MA.
    29
    26,323
    Are they all current?
    Have you checked for corrosion on the connector to the module?
  6. #5
    Sep 2012
    Elmhurst, IL
    15
    Sorry fixed it. No I haven't checked for it, the codes came immediately after the flooding, so I figured corrosion couldn't be the issue.
  7. #6
    69
    82,272
    This is why flooded cars get totaled. You could be looking for a needle in a haystack. Just out of curiosity, how deep was the water?
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    back in the 80's I had a customer come in with her 89 Grand Prix -
    with a check engine light on -
    hunted down the problem - fixed it - sent her down the road -
    2 weeks later she came back - with another engine light -
    check it out - completely different problem -
    one month later she came back - with her dad - another check engine light -
    she was getting pissed at US - asking WHY we can't fix it completely -
    I reminded her - each time the check engine light came on -
    it was a completely different - and unrelated problem -
    then her dad asked if it made any difference if the car had been under water -
    WELL - YA -
    he explained the car had been flooded -
    the girl only had liability insurance - ON A ONE YEAR OLD CAR -
    and the flood damage wasn't covered -
    so - he and the daughter took the seats and carpeting out -
    dried everything out - and put it back together -
    a took a year for the problems to begin -
    EACH AND EVERY CONNECTOR WAS CORRODED -
    like Ranger said - there is a reason flooded car are totaled -
    they will NEVER be right -
    for your car - I WOULD NOT TRUST THE AIRBAG SYSTEM EVER AGAIN -
    they could go off an any time - for any reason -
    just leave the airbags out or disconnected -
  9. #8
    Sep 2012
    Elmhurst, IL
    15
    The water originally was just bellow the door and I was able to open the door without water getting in so as I was carefully getting out to try to push it back out of the water (it had died out) a fire truck went flying by and flooded it...it was only slightly above the carpet maybe an inch or less above it it wasn't THAT much water I don't think. I just don't see anything else besides the SRS unit really could have gotten damaged. The way these codes seem to me is that they all pretty much just point to the unit being fried and needing new bags installed. and a new ABS brake pump... I'm probably being really optimistic when I say that too...
  10. #9
    69
    82,272
    Did you pull the carpets and dry everything out? Did you check everything that was below the water line?
  11. #10
    Sep 2012
    Elmhurst, IL
    15
    Yes, took everything out and did a very through cleaning and drying to everything.
  • You may not post replies
