Alternator/electrical
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Alternator/electrical in Past Cadillac Vehicle Discussion; I was driving than at a red light the lights on the dash right side of the steering wheel came ...
    cajunboy is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jun 2013
    TOMBALL,TX.
    89
    I was driving than at a red light the lights on the dash right side of the steering wheel came on. The battery light did not come on. So at the next red light I stalled but it started right back up and the lights on dash went off. So I noticed the volts stay on 14.5 than quickly drops to 12.5 btttghjfdbackanbbbackback to bh
    Omit the last part of that. 12.5 than it goes back up to 14.5. I got home parked and with engine off it is at 12.5. Engine on 14.1 than climes to14.5. Put ac rear defrost on and it goes to 12.8 to 13.6. Car never stalls seems normal. So I take a ride and it stalls at a red light and now check engine light comes on. Start it right up and I go straight to autozone. Engine light goes off. So I get them to check battery/alternator and he says its good. Why am I stalling out and dash lights coming on than off. Is it the beginning stages of alternator going bad ,lose or dirty wire. Crap pls help
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Did you pull the codes yet?
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Quote Originally Posted by cajunboy
    Check your battery cables. I wouldn't just assume its the alternator. You need to pull the codes from the car and see what the PCM is telling you. Right now it could literally be anything from a vacuum leak to bad ignition coils to a bad battery. See what the codes are and start from there.
    Jun 2013
    TOMBALL,TX.
    89
    I asked the guy to do it. The check engine light went off as I was going to AZone. He told me he can't pull it unless the check engine light is on. Can I pull it on the onboard system.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Re: Alternator/electrical
    AutoZone is full of IDIOTS -
    YEP -
    and anytime something acts up -
    the very FIRST step should ALWAYS be to -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Jun 2013
    TOMBALL,TX.
    89
    What are the symptoms of a bad alternator. What code indicates bad alt. someone knows I'm sure. What is confusing me is that the battery light didn't come on.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Quote Originally Posted by cajunboy View Post
    once again - with more feelings -
    CHECK FOR CODES YOURSELF -
    USING THE BUILT-IN SCANNER -
    Jun 2013
    TOMBALL,TX.
    89
    Ok po335- crankshaft position sensor A circuit performance
    BO429- temp. Control 3 rear circuit range performance
    CO655- level control relay
    U1000- class 2 comm. malfunction
    Engine light finally came on I did the test and PO335 is what caused the light to come on because I cleared the code and engine light went off.
    So this is want is causing my problem. It does not seem hard to replace.
    Do I have to get the PCM reprogrammed by a dealer.
    Can I drive the car like this until Friday just to go to work. It would greatly appreciated if I can get details on the best way to replace this. Thanks
    Jun 2013
    TOMBALL,TX.
    89
    Also part number for 2002 deville would be cool. I just got to work about 20 miles from where I live and nothing happened this time wierd. Holla back
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    P0335- crankshaft position sensor A circuit performance
    BINGO -
    this is a known problem - the original sensors were NFG -
    made in Mexico - one tan and one gray -
    the new ones are made in Japan - and are black and gray -
    YES - replace them BOTH -
    gee - do you want me to install them for ya too?
    CKP - Crankshaft Position Sensors -
    ACDelco 213-1578 - $37.97 - with free shipping -
    from amazon.com -
    and -
    ACDelco 213-1579 - $43.19 - with free shipping -
    also from amazon.com
    just tight working space - easier if you remove the oil filter adapter -
    if you do that - you will need 2 new "O" rings -
    you mean the relearn - 99.99% of the time - NO -
    maybe - possibly - probably -
    check in the TechTips Forum -
    or possibly in the Northstar Performance Forum -
    there should be something there -
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    The IC will tell u Battery not charging
    Your battery volts on the IC may be below normal
    A couple indications u should check your codes...
    But looks like u found it...
    Jun 2013
    TOMBALL,TX.
    89
    Once again basscatt you Rock. Yes i can rule out alternator. How about getting the ckps at a auto parts store because I like to do it Friday I am off work. Would you recommend a different brand. Thanks
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    glad to help -
    I don't there IS an aftermarket replacement -
    but even if there was - NO - NO - NO - A THOUSAND TIMES NO -
    How about getting the ckps at a auto parts store -
    you can call around and ask - you have the part numbers -
    you could get them from the dealer - and pay 3 times the price -
    Amazon ships fast - and they do have 2-day shipping -
    http://www.amazon.com/ACDelco-213-15.../dp/B000C9HW00
  16. #14
    Jun 2013
    TOMBALL,TX.
    89
    Ok I am concerned about the relearn. The Haynes manual and other web sites suggest to get it relearned. But since the car has a built in scanner it would relearn itself right. I know basscatt explained I should not have too. I just hope I change out these ckps and can just take off when I am done.
  17. #15
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Relearning after CKP replacement? Usually it'll have no problem unless you have problems after the repair, which I have never seen one yet.
  18. Remove Advertisements
