1999 Deville headlight swap to a 1995???
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By SUPER LAC DEVILLE
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 Deville headlight swap to a 1995??? in Past Cadillac Vehicle Discussion; Has anyone done a headlight swap from a 99 Deville to a 95? I found the lights in the yard ...
    Stroked Cutlass is offline Cadillac Owners Member
    Automobile(s): 1995 Deville
    Jul 2013
    25
    Has anyone done a headlight swap from a 99 Deville to a 95? I found the lights in the yard and I would really like to put them in my 95. The look a little different but does not look to hard to do. Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    They're a different shape IIRC.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: 1999 Deville headlight swap to a 1995???
    I don't think it will work.
    It definitely won't be a direct swap.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    only if you can swap out the entire front clip -
    Jul 2013
    25
    It looks like they will bolt in but it is a different shape were they fit against the grille. It also looks like the side lights are shorter so I would have to use the lights off of the 95. I would like to do H.I.D lights on my car and have the updated lights to go with it.
    Sep 2010
    East Boston MA.
    29
    26,325
    Unless you do a projector conversion, installing HIDs would be illegal, put less usable light on the road, and cause glare for other drivers.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    Quote Originally Posted by Stroked Cutlass View Post
    whether you use the 95 headlights -
    or somehow use 99 headlights -
    they are both REFLECTOR type headlights -
    HID lights are illegal to install in REFLECTOR type housings -
    YES - they are brighter -
    but will actually put LESS useable light on the road -
    and will blind oncoming traffic -
    if you would like additional information WHY this is true -
    and WHY there is no way to correct the problem -
    I can provide a complete description -
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    I tried to use HIDs and its like the guys here say, Brighter but Less road light
    I switched back the same night
    basscatt likes this.
  11. Remove Advertisements
