ac replacement question entire system or just compresor
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, ac replacement question entire system or just compresor in Past Cadillac Vehicle Discussion; just one question what are the chances of my ac going out again if I don't replace everything ....was just ...
    eddielnordman's Avatar
    eddielnordman is offline Cadillac Owners Member
    Automobile(s): 1995 DeVille 4.9L (with skirts)
    May 2013
    phx az its hot over here
    42
    63
    just one question what are the chances of my ac going out again if I don't replace everything ....was just going to replace the compressor/w clutch....kinda limited on the money front but wondered if I am just setting my self up to mess up system by not getting the complete kit...found a new compressor for 220....with free shipping....lol oh ya I live in az lol...and its hot lol
    RicMir is offline Cadillac Owners Member
    Automobile(s): 2004 Devillle Base 4.9 Northstar
    Jul 2013
    Rushmere VA
    8
    Just a note that your condenser can not be flushed. Generally when we do a compressor at my shop we change the condensor also.
    68
    82,055
    Re: ac replacement question entire system or just compresor
    Quote Originally Posted by eddielnordman View Post
    It all depends on what failed and how. If the compressor failed internally and started throwing debris through the system you'll need to replace the condenser, orifice tube and accumulator as well as flush all the lines. Pull the orifice tube and see if the screen is full of debris. If it's clean, you may be OK.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    ------------------------------------------ -----------100% CORRECT -
    IF the old compressor blew - and IF the orifice tube DOES have debris in it -
    I would STRONGLY recommend installing an in-line filter - ACDelco-15-1747
    to protect the new compressor -
    $26.87 - with free shipping -
    http://www.amazon.com/ACDelco-15-174.../dp/B0016IXF7A
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    This is the inline filter I used. Catches the debris before it has a chance to clog the orifice tube. Installs in the liquid line.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Quote Originally Posted by Jfarr View Post
    that one is OK - very small - and more expensive -
    but better than nothing -
    68
    82,055
    The orifice tube screen is a very fine mesh. Isn't that in itself a filter?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    well - yes - but - it is a "last-chance" type "filter"
    and it doesn't take very much to clog it up -
    my shop ALWAYS installed the in-line filter I pictured -
    VERY cheap insurance - and 99.999% effective -
    back then - many compressor suppliers REQUIRED one -
    as a condition of their warranty -
    68
    82,055
    Quote Originally Posted by basscatt View Post
    No argument there.
    Jun 2013
    65
    Installs on the suction side yes? Don't most systems have a filter/accumulator/dryer on the low side? My thinking is it would be better to stop the debris before it entered the condensor and the orifice tube.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    most systems do not have any filter -
    which is why I suggested one -
    the most important thing -
    you MUST prevent debris from getting into the compressor -
    the only thing with moving parts -
    and it's much easier and safer tapping into the low pressure side -
    than messing with the high pressure side -
    May 2013
    42
    63
    the clutch burned up and I swapped belts to keep it from freezing ....thanks for the help ....but I think I was a bit late bunch of dust and some small particles under clutch in drive way ...better safe than sorry thanks again all....love my cadi....
    Jun 2013
    65
    Bought my compressor kit from these guys. Comes with the compressor (filled with 7oz. oil), orifice tube, accumulator/drier/filter and "o" ring kit. Pulled the radiator, condensor, alternator to get to the compressor. Not too bad of a job.
    I added a condensor and the inline filter.
    I was impressed the parts arrived the day after I ordered them!
    My AC works like new.
  16. #14
    Jun 2013
    65
    Compressor bad, to be replaced under warranty.
  17. Remove Advertisements
