2001 DHS not starting, B 0429 code current
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 DHS not starting, B 0429 code current in Past Cadillac Vehicle Discussion; My 01 DHS didn't start on first attempt the other day then turned the key a 2nd time and it ...
    forsman959@yahoo.com is offline Cadillac Owners Member
    Automobile(s): 2001 DHS
    May 2013
    9
    My 01 DHS didn't start on first attempt the other day then turned the key a 2nd time and it started. Then after sitting at work, it would not start. The relay was firing but no action from the starter. We made sure fuses were secure, etc and nothing. Valet key would not make a difference. I put the fuse covers back then bam, car started right up but the engine light came on. The only current code was a BO429 but the light disappeared when I started a few hours later and hasn't come back on for 2 days and car has been starting fine.
    Any thoughts?
    70cougar is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    608
    B429 is back seat A/C vent, not your problem. Since you had SES light , you must have a P code listed as "history".
    May 2013
    9
    PO3040 in history
  5. #4
    Dec 2009
    Connecticut
    608
    Quote Originally Posted by forsman959@yahoo.com
    PO3040 in history
    Misfiring cylinder - possible bad or loose coil or bad plug. But that would not account for starter not working. What shape is your battery? Voltage reading 1/2 hour after running?
  6. #5
    May 2013
    9
    The misfire is in history. The check engine was only on this once during the last 4 months and the only current code was the BO429.
    I've read about loose shifting cables possibly bring the cause, making the car think its not in park. I've heard that bad starters are very rare in the Deville.
  7. #6
    Dec 2009
    Connecticut
    608
    Bad starters are rare but loose starter cables happen. And bad battery or loose battery cables are real possibilities.
  8. #7
    Automobile(s): White Diamond '03 DHS (with floor shift)
    66
    70,385
    Re: 2001 DHS not starting, BO429 code current
    Did the engine crank, but fail to start or did it not even crank?
  9. #8
    basscatt's Avatar
    basscatt is offline Cadillac Owners Master
    Automobile(s): 89 Coupe DeVille, 95 Sedan DeVille, 02 DHS, 03 SLS
    Feb 2004
    Minnesota
    62
    8,444
    Quote Originally Posted by forsman959@yahoo.com View Post
    PO3040 in history
    PO3040
    there is no such code - too many numbers -
    P0304 Cylinder 4 Misfire Detected -
    but that code would NOT be available without using an external scanner -
    and P3040 does not exist -
  10. #9
    May 2013
    9
    Obviously a misfire is not my problem. The starter didn't make a sound, no clicks, nothing would happen.
  11. #10
    66
    70,385
    Then I'd start by checking the battery.
    P.S.
    Please update your profile to show the year and model.
  12. #11
    basscatt's Avatar
    Feb 2004
    Minnesota
    62
    8,444
    obviously -
    ignition switch -
    neutral safety switch -
    starter solenoid -
    lose starter wire -
    bad ground -
    good luck -
  13. #12
    Submariner409's Avatar
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    74
    41,584
    Car and year fixed.
    forsman, it is NOT a good idea to show your e-mail where the entire world can see it. You will (not might - WILL) wind up with far more e-mail than you bargained for.
    How old is the battery ??? Any more than ~5 years and it is a prime suspect.
  14. #13
    May 2013
    9
    Still having problems here, guys. BO429 is the only current code w/ PCM PO340, PCM P1617, and IRC U1016 are in history
  15. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    62
    8,444
    OBVIOUSLY cars don't fix themselves -
    and I see you were able to copy the codes correctly this time -
    P0340 - Camshaft Position (CMP) Sensor Circuit -
    won't cause a "dead" starter -
    but WILL affect how the engine runs -
    P1617 - Engine Oil Level Switch Circuit -
    also won't affect the starter -
    but WILL cause/prevent the CHECK OIL LEVEL message -
    P1617 - Loss of Class 2 Communication with VCM -
    did you check any of the possibilities I listed in #11 ?
    the cable at the starter solenoid is a good place to start -
  16. #15
    Feb 2006
    74
    41,584
    Re: 2001 DHS not starting, B 0429 code current
    B 0429 = Bee Zero Four Two Nine - Current
    P 0340 = Pee Zero Three Four Zero - History
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
