03 DeVille Base Rear windows inop after replacing both regulators and motor
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 03 DeVille Base Rear windows inop after replacing both regulators and motor in Past Cadillac Vehicle Discussion; Hello Fokes, My mother dropped this POS 2004 Cadi Deville in my lap after her "so called mechanic some late ...
    RicMir is offline Cadillac Owners Member
    Automobile(s): 2004 Devillle Base 4.9 Northstar
    Jul 2013
    Rushmere VA
    8
    Hello Fokes,
    My mother dropped this POS 2004 Cadi Deville in my lap after her "so called mechanic some late 70 year old man" told her she needed new window regulators
    due to the windows going down and staying down. So as her son I am a Tech for pepboys an i have searched alldata and i am not finding any luck with this.
    So i replace both regulators with motors and while testing the window went up then down then dead. now i am dead at the Main switch also.
    from what a buddy that works at a cadi dealer in VB said it sounds like the door control module now. I am not stupid an i know that electronics can fail with the slightest
    thing.
    Has anyone seen this when i connect my Versus Pro. there is no DTC listed only in Airbag. and thats due to a cracked wire in the front of the car from hitting a deer this past xmas. I am at my whits end . you got any help please advise.
    Thanks in advance
    Ric Mir
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,363
    Re: 03 DeVille Base Rear windows inop after replacing both regulators and motor
    Quote Originally Posted by RicMir View Post
    Hello Fokes,
    thing.
    Thanks in advance
    Ric Mir
    step 1 - use the ON-BOARD SCANNER -
    and check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS
    check ALL the fuses under the back seat -
    then check the wiring harness between the front of the rear door - and the door pillar -
    report back with your findings -
    Jul 2013
    Rushmere VA
    8
    ok right about now i want to throw my 8500 $$ Verasus Pro across my shop. ok i have a TON of Codes. the one that makes the most sense to me is .
    DIM U1064 Loss of communication to DIMM
    DIM U1301 Class 2 Short to ground.
    ABS U1301 Class 2 Short to ground
    Why wouldn't my Verasus see these
    Wow wicked. so what its saying is the car has a bad ground somewhere. ?
    68
    81,902
    Because most aftermarket code readers only read PCM codes, not B (body), C (chassis) and U (network) codes, although for $8500 I would expect it to do that and a LOT more.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,363
    "U" codes come and go regularly -
    for the most part - they are a momentary "hick-up" -
    in the data line - and can be ignored -
    these are NOT your problem -
    as I said earlier - inspect the wiring harness from the door to the door pillar -
    Jul 2013
    Rushmere VA
    8
    Ranger its a Snapon Verasus Pro unit.
    I bought it used off the snapon guy that comes to my work (Pepboys) but I am going to bull the wiring harness out tomorrow a ince I am off. As I been working on this car. Done everything from head gasket to power seat control module. I will keep it posted. An thank you for your help.
    Jul 2013
    Rushmere VA
    8
    Think I fight have figureded this out. There is a bad grou d some where at the switch come out of the door control module. I am not getting a steady 12.2. Volts. I am thinking door contold module has come bad. Down side looking over 100.00 to even test the theory. But moving up on step at a time. I did test both motors from a 12v craftsman power drill battery an the motor words great.
    Will keep my findings posted.
    Ric Mir
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,363
    Ric Mir
    doubtful - if the Driver Door Module was bad -
    you would get DDM related codes -
    rodnok01's Avatar
    Feb 2012
    NC
    6,629
    Did you check pillar wiring?? The wires break from door to pillar all the time.
    Jul 2013
    Rushmere VA
    8
    Quote Originally Posted by rodnok01 View Post
    i have torn this door pillar apart . checks comuimity all wires are good . I am thinking is the Rear Door Module
    Jul 2013
    Rushmere VA
    8
    Ok I am about to give up from the drivers seat I can hear a click dound coming from middle door location. Theres got be that rdm rear door module. Thats gone bad
  14. Remove Advertisements
