Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: 93 Coupe Deville 4.9 Ignition Timing please help
    Jonathan11 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Coupe Deviile
    Jul 2013
    34
    I'm trying to set the ignition timing on my car, I crossed the ALDL terminal A and B, I thought I've found the timing marks but I guess I'm wrong. Every time I move the distributor close to the marks the engine almost dies so they can't be the marks. Could anyone describe what the marks looks like? If you so happen to have a picture that would awesome. Thanks for any help.
    69
    82,278
    Re: 93 Coupe Deville 4.9 Ignition Timing please help
    Why are you messing with the timing? Once the base timing is set it should never move and the PCM takes it from there.
    Courtesy pf Dennis93Coupe
    Jul 2013
    34
    Thank you so much for helping me out with this.
  5. #4
    Jul 2013
    34
    The reason I'm messing with the timing is my intake manifold gaskets went out and that required me to take the distributor out.
  6. #5
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    That is a good enough reason. Btw, the picture is to help you locate the mark on the damper. I assume you know where the timing pointer is located. Make sure you have turned off all accessories including the A/C. Any rpm below 800 will work.
  7. #6
    Jul 2013
    34
    Hey, if you have a pic of what I should be lining that mark up with I would really appreciate it if you send it to me. The only thing I see is would be ATDC. I'm thinking that the timing mark isn't at TDC but I just want to be sure. Thanks again for taking the time to help me out.
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Quote Originally Posted by Jonathan11 View Post
    I believe the correct timing for your car is -
    10* BTDC - Before Top Dead Center -
    not After Top Dead Center -
    the stationary timing mark looks like a bunch of teeth - /\/\/\ -
    although I don't remember which represents 10* BTDC -
  9. #8
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    hope this helps yo get the general idea 12 to 14 will give you a little better performance but you have to run 91 and higher or you will ping
    0 4 8 12 16 20
    2 6 10 14 18
  10. #9
    Jul 2013
    34
    Thanks for all your help. I know it's always set advanced but I was thinking the timing mark at the hub would be top dead center and the one on the block would be advanced. Guess I was wrong. Well thanks again.
  11. #10
    Jul 2013
    34
    1993 Coupe Deville pre ignition, pinging
    The spark plugs have been replaced, I reset the ignition timing and went through all the steps like crossing the ALDL terminals. Is there anything on this car that is typical for causing a ping? I have to accelerate so slow for it not to kock. Thanks for any help.
  12. #11
    Jul 2013
    34
    Man, I cannot get this pinging to go away. The plugs have bee changed, I set the timing, and it's still having preignition. Is there anything typical on this car to cause it to ping?
  13. #12
    69
    82,278
    Re: 1993 Coupe Deville pre ignition, pinging
    Are you using premium? The 4.9 does not have a spark knock sensor.
    Are you sure you timed it properly? What did you set the base timing at? It should be 10 degrees BTDC.
    Have you checked for vacuum leaks?
    Is the EGR working properly?
    Have you pulled the DTC's?
    P.S.
    Please do not double post. One thread on the same subject is enough.
    Threads merged.
    P.P.S.
    3rd post on the same subject deleted.
  14. #13
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    ^^^ was about to ask that
  15. #14
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    The timing mark on the harmonic balancer is TDC
    When you start the timing procedure #1 piston TDC compression stroke the mark on the harmonic balancer should be on 0 and the rotor pointing at 1 on the cap.
    The block Vernier scale only reads advanced there is no retarded on the scale.
    "The spark plugs have been replaced"
    Spark plug wires?
    Have you checked the fuel pressure?
  16. #15
    Jul 2013
    34
    I'm sorry about that. After I made the post I've thought to come back and ask you, it won't happen again. I always use premium, I set my timing to 10 degrees before top dead center, my car is running a little rough. I thought it was doing that because of the timing but it still is. I've check the DTC's and found nothing so far. What's a good way to check the EGR?
    On my car the teeth to line looked like it was after top dead center, I know I was mistaken.
  • You may not post replies
