I'm thinking of buying a 2000 DTS.
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, I'm thinking of buying a 2000 DTS. in Past Cadillac Vehicle Discussion; Can I get any input on this car? It seems to be in great condition, has 107k miles on it, ...
    JFlores0410 is offline Cadillac Owners Member
    Jul 2013
    Can I get any input on this car? It seems to be in great condition, has 107k miles on it, cold a/c, immaculate interior and exterior but the one thing that is turning me off about her is that there is a very slight oil leak...
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What to look for in these cars has been discussed many times in the FWD Deville/Fleetwood forums.
    In a nutshell, other than the obvious used car checks:
    - Make sure it doesn't need shocks or struts, they're active and EXPENSIVE.
    - Window regulators are a fairly common common failure on last gen Devilles. There's a cheap and permanent solution to the problem.
    - The blend door actuator for the rear seat temp control will most likely be broken.
    - Read the "sticky" thread at the top of the FWD Deville/Fleetwood page on how to pull DTCs, and do so.
    - Drive the car HARD on the test drive, plenty of WOT. If the temp needle moves more than a couple of "ticks" past the center line, WALK.
    - I highly recommend performing a block test (a chemical test that indicates if there are traces of combustion gasses in the cooling system, a sign of HG failure) on any Northstar powered vehicle.
    The oil leak could be anything from a $2 O ring, to a leaking half case seal that requires drivetrain removal and major engine disassembly.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,718
    Re: I'm thinking of buying a 2000 DTS.
    Quote Originally Posted by moistcabbage View Post
    - drive the car hard on the test drive, plenty of wot. If the temp needle moves more than a couple of "ticks" past the center line, walk.
    RUN!
