03 DeVille HVAC blower speed problems on A/C
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 03 DeVille HVAC blower speed problems on A/C in Past Cadillac Vehicle Discussion; My fan speed will not go to full blast when the A/C is on and the recirc is running. If ...
    2dfx's Avatar
    2dfx is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac DeVille
    Jun 2003
    Ontario, Canada
    31
    397
    Question03 DeVille HVAC blower speed problems on A/C
    My fan speed will not go to full blast when the A/C is on and the recirc is running. If I do, it runs for about 5 seconds then shuts off...then comes back on for another 5 secs or so and repeats.
    If I set the fan speed to 4/5 it operates normally. Annoying when the unit is set to 'Auto' and I have to keep adjusting it because the fan won't stay on. Heat works fine at any speed.
    Ideas?
    68
    81,883
    Re: 03 DeVille fan speed problems on A/C
    I'm guessing that the blower is on it's way out.
    2dfx's Avatar
    Jun 2003
    Ontario, Canada
    31
    397
    If it didn't work at ALL on full speed I would think this is likely. But it dies sporadically only when the recirc is on? Seems fishy.
    68
    81,883
    ONLY in recirc?
  7. Remove Advertisements
