accelerator issues
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, accelerator issues in Past Cadillac Vehicle Discussion; I have a 99 DeVille thats likes to accelerate without my foot on the accelerator. RPM over 3,000. I had ...
    kodak is offline Cadillac Owners Member
    Automobile(s): 1999 Deville
    Mar 2013
    15
    accelerator issues
    I have a 99 DeVille thats likes to accelerate without my foot on the accelerator. RPM over 3,000. I had to shut down the car. once I started it back it was back to normal. Sometimes I can kick it down. I have disconected the cruse control. and replaced the throtle control unit ($350.00) Still a problem. I can drive for days and it runs fine.
    I pulled the codes
    pmc 1654
    tcs c 1225 or 1225
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,625
    Definitions for codes?
    Mar 2013
    15
    Re: accelerator issues
    where can I find them ?
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by kodak View Post
    I pulled the codes
    pmc 1654
    tcs c 1225 or 1225
    Your C1225 is the first code to address.
    C1225 - Left Front Excessive Wheel Speed Variation
    Either a nasty dirty hub wheel speed sensor connector OR a failing wheel speed sensor which requires hub replacement to repair.
    68
    81,889
    Clean the TB first.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    This happened long ago in my Deville before I took over the ownership. It received no TB cleaning since 1999. I cleaned the TB and it never happened again. Now I clean mine once in every year.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    64
    344
    Clean the TB and check/lube the throttle cable.
    Also, make sure the carpeting (or residue from carpet or shoes) is not interfering with the pedal. Pedal should be nice and free, with no sticking at all.
    68
    81,889
    Lube attracts and holds dirt. I don't believe the throttle cables are intended to be lubed.
  11. Remove Advertisements
