93 Coupe Deville 4.9 Ignition Timing
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 93 Coupe Deville 4.9 Ignition Timing in Past Cadillac Vehicle Discussion; I changed the head gaskets on my 93 coupe deville and it I had to take the distributor out. I ...
    Jonathan11 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Coupe Deviile
    Jul 2013
    34
    I changed the head gaskets on my 93 coupe deville and it I had to take the distributor out. I put everything back together and now I'm trying to set my ignition timing. I crossed the ALDL terminals A and B with a paper clip and put my timing light on cylinder one and I can't line up the timing marks. The closer I get it to the timing marks the crappier it runs and it dies before it lines up. The lines on the hub is like 90 degrees advanced. It goes back to running fine when I move the distributor back from lining it up. I stuck a long tooth pic down cylinder one and manually got top dead center and the marks are on the right spot. Thanks for any help.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    How do you know if the long tooth pick was on a compression stroke or exhaust?
    how do you know the distributors is not a 180° off?
    Jul 2013
    34
    Re: 93 Coupe Deville 4.9 Ignition Timing
    Because regardless of where the distributor is the timing light is going to respond to the signal. And compression and exhaust are pretty close to each other, piston position speaking.
