95 deville vibe in front end
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 95 deville vibe in front end in Past Cadillac Vehicle Discussion; Recently put new struts on and got it aligned. Rides a billion times smoother except for a vibe while moving ...
    SuperMidget is offline Cadillac Owners Member
    Automobile(s): 1995 base Deville
    Jul 2012
    34
    35
    Recently put new struts on and got it aligned. Rides a billion times smoother except for a vibe while moving the wheel any to the right.
    Moving to the left even a fraction of a turn and the vibe goes away completely
    My question is.. I know I need rotors up front as the passenger side is warped giving me a decent vibe under braking, are the 2 problems related? The vibe while moving the wheel right is minimal... equal to say going down a smooth gravel road
    PO put new pads up front but the rotors are shot on both sides
    68
    82,070
    Re: 95 deville vibe in front end
    You should only feel a rotor vibration when braking, not turning. That may well be a bad (left) wheel bearing.
    Jul 2012
    34
    35
    Checked all that last Monday while it was up on the rack for the alignment. I know I have a tie rod getting a little wore on both sides but not enough to worry about yet
    Driver side hub is newer but the passenger side is factory for all I know...
    I had considered it but hoped I was over reacting haha... wheel bearing with enough slack that turning right places just enough side pressure for the warped rotor to rub the pads
