Deville 94 4.9 V8 - no start - Page 2
Results 16 to 30 of 37
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Deville 94 4.9 V8 - no start in Past Cadillac Vehicle Discussion; Yeah it was the battery but now I think my starter went. I'll upload the sound recording I made of ...
  1. #16
    CaptainAmericaUSA is offline Cadillac Owners Member
    Automobile(s): Devillie 94 4.9L V&
    May 2013
    27
    Re: Deville 94 4.9 V8 - no start
    I'll upload the sound recording I made of the sound it makes when the car goes to start and doesn't shortly.
    I'm really depressed I was suppose to see my girl today sigh.
    It makes a whining sound when I go to start it.
    How much should the starter or the starter solenoid cost to replace?
  2. #17
    68
    81,916
    Whining sound? Do you mean a loud screeching sound?
    Starter is around $50 - $100. Add markup and labor.
  3. #18
    May 2013
    27
    Yes just like a screeching sound like a grinding noise almost.
    I have to figure out a way to upload the link from my phone of the voice recording on here.
    Is it easy to fix the starter by one's self or should I take it to a garage?
  5. #19
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    It shouldn't be too hard to do yourself. You can see it from under the hood but easier to get to from underneath.
  6. #20
    May 2013
    27
  7. #21
    May 2013
    27
    Does that sound clip sound like the starter?
  8. #22
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It sounds pretty normal to me. I hear a pretty smooth turning over but no start up. Does the car start now?
  9. #23
    68
    81,916
    I couldn't make much out of that sound clip. I certainly did not hear any screeching (kind of like when you try to start a car that is already running, if you know what that sounds like).
  10. #24
    May 2013
    27
    The girl at O'reilly auto parts who knows a lot of about cars was on the phone when I went to start my vehicle she said it sounds like a bad starter.
    It still won't run.
    It seems like it is always something with my car. Every payday my car takes me to the bank and cashes all my money.
  11. #25
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The engine's turning over just fine. It's not the starter.
  12. #26
    May 2013
    27
    What else could it be?
  13. #27
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    First - Check for codes
    Then
    check every fuse in the vehicle.
    Check for spark
    Listen for the fuel pump when you turn the key on. It should do a couple of second prime.
    Break out the fuel pressure gauge (sometimes you can get a weak pump).
    open the filter box and see if it can get air.
  14. #28
    May 2013
    27
    Quote Originally Posted by amunderdog View Post
    Then
    Check for spark
    I hope it's not the fuel pump I've already changed out all the fuel injectors which is a pain for no reason along with new spark plugs rotor cap and wire including a new fuel pump and sender.
    I refuse to pay for another fuel pump or sender unit that almost killed me money wise.
  15. #29
    68
    81,916
    This thread is beginning to get confusing (like so many others).
    Lets go back to basics.
    Does the engine crank?
    If no, battery, cables, connections, starter.
    If yes, check for spark at the plugs. Check your fuel pressure (should be 40-50 psi).
  16. #30
    May 2013
    27
  17. Remove Advertisements
