'91 Deville, a few questions
Results 1 to 6 of 6
Like Tree2Likes
  • 4 Post By Faith76
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '91 Deville, a few questions in Past Cadillac Vehicle Discussion; Greetings. I'm new to the forums. I don't know what kind of modifying you guys do, but that's a bit ...
    Beuks is offline Cadillac Owners Member
    Automobile(s): 91 Sedan Deville
    Jul 2013
    1
    Greetings. I'm new to the forums. I don't know what kind of modifying you guys do, but that's a bit of what I'm looking for.
    Now, I've got a couple questions. First off, I've got a '91 Sedan DeVille with 183k miles on it. The engine still runs like a champ, but it idles a little rough. It doesn't just sit there and purr. It surges a little. The variance is maybe 100 RPM, so nothing huge, but I'm wondering if this is normal with old age or if I should worry. It also does it worse (~100 RPM, maybe worse) when I press the throttle lightly and rev it ~1k RPM and hold.
    Second, I'm wondering about transmission swaps. I understand that the stock 4T60-E is strong, but mine is getting up there (original trans. as far as I know) and I'd like something with better gearing (I want lower revs at cruising speeds), in a manual transmission if I can. My biggest concern with the manual transmissions, though: The ones I know of were all behind smaller, less powerful engines, so I'm concerned with reliability, especially in this car because it's bigger than anything these transmissions were ever in. I'm also concerned with how exactly the computer would react if there suddenly weren't a transmission controller for it to communicate with. Would it throw codes, would it retard the performance of the engine, etc.
    Third, I would really like to know about the aftermarket upgrades for this car. I've heard of next to nothing that can be done with these engines, aside from a K&N drop in filter, an Allante intake, and catless higher-flow exhaust. Mine currently has the K&N drop in, and a stock muffler modified for dual 3-inch outlet with stainless angle-cut tips. Where can I go (online) to buy aftermarket upgrades, and what can be repurposed from other engines to improve this one? Also, I don't actually remember what kind of improvement I can expect from the Allante intake.
    Thanks for whatever input you can offer. Direct me where you can.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Most members here aren't into modifications, which is just as well, because there is NO aftermarket support for these cars, brake pads and tires, thats's IT.
    Your car already has a CAI that flows more air than the engine can use at WOT, at redline. And FWIW, K&N filters don't make any measurable difference, flow more dirt, and pack up 3 times as fast.
    Exhaust mods will get you sound, but no more than one or two more HP.
    If there was a manual transmission that would work with the 4.9, and bolt into the car, the car electronics would not be happy. And what would you use for seats, a console, shifter and linkage?
    These are the WRONG cars for tuners.
    As for the surging, is it surging up and down, or could you call it a stumble?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: '91 Deville, a few questions
    You forgot to mention when it was tuned up last. I would run some Techron in the gas for starters.
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    I just don't understand why you'd want to make a Cadillac loud.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,559
    Quote Originally Posted by Beuks View Post
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    clean the throttle body - make sure the egr tubes are clear -
    no other trans is available -
    that's an easy one to answer -
    there are none - nada - ZERO - ZILCH -
    pleated paper filters are actually better at trapping dirt -
    and a regular paper filter will flow more air
    than the engine can suck at full throttle - at redline -
    pure bling - zero gain in power or mileage -
    no where - because there is nothing to buy -
    nothing - absolutely nothing -
    nothing -
    you bought the wrong car for modding -
    BLING - like wheels and tires -
    better brake pads and rotors -
    and that's about it -
    dommi.b is offline Cadillac Owners Member
    Automobile(s): 1995 Deville Base 4.9L
    Sep 2012
    Elmhurst, IL
    15
    I agree, a quiet ride is what you'd want in a luxuy car like the deville... but boy do these 4.9L's sound good with straight pipes!
  9. Remove Advertisements
