Questions - 1997 Deville repair and maintenance - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Questions - 1997 Deville repair and maintenance in Past Cadillac Vehicle Discussion; Alright. I'm gonna go check it out real quick....
  1. #16
    AlcoholicProgram is offline Cadillac Owners Member
    Automobile(s): 1997 DeVille
    Jul 2013
    20
    94
    Re: Questions - 1997 Deville repair and maintenance
  2. #17
    rodnok01's Avatar
    Feb 2012
    NC
    6,624
    As Karl would say.... "Alright then...."
  3. #18
    Jul 2013
    20
    94
    Well I checked it, the fuse seemed good. I went ahead and replaced it to just to be sure. Still no luck, no lamps coming on at all.. No trunk, hood, or interior lamps..
    EDIT: You said the "Inadvertent power" is that it doesn't turn everything off after 10 minutes. Could it be that all the bulbs just got burned out?
  5. #19
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    The interior light relay was bad on my 97 Deville. O' Reilly's had a replacement
  6. #20
    rodnok01's Avatar
    Feb 2012
    NC
    6,624
    No way did all the bulbs go at once.
    The inad relat turns power off after 10 min, connected to that relay is interior light relay....so if inadv is bad no light or if int relay bad no lights.
    Did u swap the relay yet to check it? Don't buy new until you find out if bad, and ebay has packs of 4 or 5 for 20-25 while local they are 13-17 each.
  7. #21
    Jul 2013
    20
    94
    I have not yet, I will go do that. Where are the relays located? And, after swapping the fuse the hood light did come on, didn't notice that until last night. I only assumed the rest of the lights went out due to that whole "timer" thing. I don't know how long the vehicle has sat like that, and how long it has had that issue.
  8. #22
    Jun 2013
    65
    Fuses and relays are located under a cover that is just in front of the LH shock tower. The inadvert relay is kinda out there by itself.
  9. #23
    Jul 2013
    20
    94
    Does anyone have a wiring diagram for the inadvertent relay? I had to get a new connector, and a new relay. The new connector is not colour-coded like the old one, it's just white and grey.
  10. Remove Advertisements
