swap passkey and key cylinder (ignition switch) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, swap passkey and key cylinder (ignition switch) in Past Cadillac Vehicle Discussion; ...
  1. #16
    jokken is offline Cadillac Owners Member
    Automobile(s): 2003 deville base - blk
    Sep 2012
    38
    24
    Re: swap passkey and key cylinder (ignition switch)
    so, I consider myself very fortunate. I couldn't get to the locksmith yesterday so I decided to try the relearn procedure with just the keys from the key cylinder I got from the 2002 deville in the salvage yard (the "matching" passkey3 from the salvaged 2002 was also already installed in my 2003 deville, the 2 passkey3's did have different part numbers, the stickers even showed different software versions between the 2002 and 2003, I’m glad they were interchangeable) (cost $75 cash at the salvage yard)
    so after the 30 minute procedure (3 cycles of10 minutes) the car started right up, no DTCs no nothing. And as one of the links said I turned it back off put in the other key and turned it to the run position and the security light went off in 15 seconds and the second key was learned and the car started right up again with that key.
    I see now my EGR replacement is good too. I had just finished an EGR replacement and had the rear ignition coil pack off too. And the car never started after. Now you see why I was worried I was chasing the wrong issue. I worried I broke something else doing the EGR job.... especially because when passkey3 was disabling the start of my car I just was getting nothing from the starter and I did unexpectedly hear the fuel pump turn on, so that worried me more. I consider myself very fortunate.
    so one question I have is why the need to relearn keys if the passkey3 is from the same car the keys and key cylinder came from? I am guessing the answer is that the passkey3 is not the module that actually learns the key, it is some other module further down the line....?
    i dont think you normally need a replacement passkey3 for this procedure, I just did cause I broke mine trying to get the key cylinder to turn... (neanderthal) meaning you should be able to replace the key cylinder and ‘relearn’ the new keys using the procedure.
    thanks moistcabbage.
    98eldo32v thanks for all the info, the links and the procedure writeup, very very helpful!
    here is another link that basically says the same procedure
    http://my.cardone.com/techdocs/PT%2077-0011.pdf
  2. #17
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    I think once the starting is disabled, the vehicle isn't going to recognize the "old" keys per se'.
    It's almost as if the pcm locks you out.
    In order to start the "learn" sequence (at least for me when I swapped columns) I needed an "unlearned" key. With the "unlearned" key NOW being introduced to the pcm, it opens a door way to program "other" keys and start the vehicle.
    Glad you sorted it out and you're up and running again.....
  3. Remove Advertisements
