Everything is fixed on the car except;
Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By CadillacLuke24
  • 1 Post By rodnok01
  • 1 Post By Mojo88
  • 1 Post By Jfarr
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Everything is fixed on the car except; in Past Cadillac Vehicle Discussion; The drivers seat. Apparently an obese person owned this car and the padding/springs have collapsed and the vinyl right above ...
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    The drivers seat.
    Apparently an obese person owned this car and the padding/springs have collapsed and the vinyl right above the seat heat control is torn. Would love to find a "lightly used" seat but may be tough to find a 97 Deville (green) drivers seat.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    Re: Everything is fixed on the car except;
    Junkyardin' time. I'd imagine you'd be able to find that plastic piece in decent condition. For the non-functioning seat heater, check the CONV (I THINK, check the owner's manual/ FSM for diagram) fuses and then the wiring under the seat. If all checks out there, time for a jyard seat heater.
    Jfarr likes this.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,632
    It looks bad because the clip is not on the back of that side panel anymore, take the screws out frt and back and you'll see a spring clip about have way sticking out of seat frame. Slide back into plastic panel and snap back into seat. it will cover the edge of leather then. Have you tested the switch for heat seat?
    Jfarr likes this.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    64
    344
    Oh man, go hit a few junk yards. You'll eventually find a perfect replacement part.
    I bought my '03 DeVille about 18 months ago. It had a loose knuckle joint in the steering column, which I could have repaired by taking the column out (and apart). The part alone would have cost ~$300. But I really wanted a telescoping steering column (which my car did NOT have). So I shopped around at a couple of junk yards and quickly found a like-new telescoping steering column from '04 DeVille. So, I fixed my steering column AND got the telescoping option too, all for ~$100!!! Gotta love a good junk yard find.
    So start making a few phone calls. Good luck.
    Jfarr likes this.
    Jun 2013
    65
    Quote Originally Posted by rodnok01 View Post
    Have not tested the switch, low priority @ 90*F
    Seat is all the way back and won't go forward, feels like the motor is trying to move it but the seat is stuck somehow. Gonna be a pain to get to those back torx bolts!!
    Took the side garnish trim screws out, I see where the clip goes but it's AWOL. Two 97 and three 98 Devilles at my local Pull-A-Part. Gonna take a morning off soon and go grab some parts!
    Jun 2013
    65
    Found the clip at the JY, repaired the seat F&R travel, life is good. What next?
    CadillacLuke24 likes this.
  9. Remove Advertisements
