Installed a new starter. Car started, but eventually died. 1994 Deville Concours
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree10Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Installed a new starter. Car started, but eventually died. 1994 Deville Concours in Past Cadillac Vehicle Discussion; After a friend installed a new starter on my 1994 Deville Concours, I decided to test drive it. (6 days ...
    Powers25 is offline Cadillac Owners Member
    Automobile(s): 1994 Deville Concours
    Jul 2013
    41
    5
    QuestionInstalled a new starter. Car started, but eventually died. 1994 Deville Concours
    After a friend installed a new starter on my 1994 Deville Concours, I decided to test drive it. (6 days later) The battery is 4 months old, but was not even connected prior to 6 days ago. I drove about 1/10th of a mile, and the battery just died. I successfully jumped it but it died after 30-45 seconds. I jumped it again, revved the engine, but it died after 30 seconds. The cluster reading read LOW VOLTAGE before it died. I am unable to get it to turn over now. It will not even crank.
    I am going to bring the battery to be tested tomorrow, but again, the battery is brand new. It is 4 months old,
    but was not used. It was however sitting in my Cadillac in 100 plus degree weather for the last two months.
    Could this have drained it?
    What are your thoughts? Do I need a new battery or alternator?
    Thank you very much for assisting me.
    Semper Fi,
    SSgt Powers
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    A bad battery is definitely a possibility. Have it charged and tested, and replaced if necessary. Once it's back in the car and the engine is running, check your voltage on the DIC.
    It sounds more like a bad alternator though to be honest.
    SGWORLDWIDE and Powers25 like this.
    SGWORLDWIDE Guest
    Re: Installed a new starter. Car started, but eventually died. 1994 Deville Concours
    yeh im with moist a bad battery would not cause a car to die u can remove the battery after the car starts and it will still run the alternator is what keeps it running and recharges the battery and is more closely linked then the starter but check the battery anyway as a failing alternator can kill the battery aswell if the voltage regulator is stuck happen to me had to replace all three starter battery and alternator
    Powers25 likes this.
    Sep 2010
    East Boston MA.
    29
    26,323
    A bad battery can absolutely cause the engine to cut out, and most modern cars will not run with the battery removed.
    The reason I suspect the alternator, is the fact that the car started and ran initially, but died while driving.
    69
    82,383
    Quote Originally Posted by Powers25 View Post
    That's no guarantee that it's not the battery. I've had them fail in 6 months. Even had bad ones right off the shelf. Don't rule it out until it's tested.
    Jul 2013
    41
    5
    Hi, I just got the battery charged, put it in, and it started right away. I let it run for about 5 minutes, and then disconnected the negative battery cable. Once I disco'd it, the car died. Is there any chance that this is not tied to the alternator? Any idea how much I will be charged to have them put in an alternator in a 94' Concours, 4.6?
    SGWORLDWIDE Guest
    Yeh i guess car companies these days dont want people pulling there car batterys out while the cars on lol though it use to be a way to test for a bad alternator i still suspect the alternator though
    69
    82,383
    Not a good idea to disconnect the battery while the engine is running on todays cars.
    Sep 2010
    East Boston MA.
    29
    26,323
    Wondering why modern cars shut down when the battery is disconnected? Take a look at your fuse box, where does it get it's power?
    Powers,
    Quote Originally Posted by MoistCabbage
    Jul 2013
    41
    5
    Ranger, why, is it computer related?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Why?? Disconnecting a battery while motor is running is a great way to cause a voltage surge which can fry the PCM, or blow any number of fuses. Why the heck did you disconnect battery while running? If you recall it's some trick your grandpa told you , forget it. Charge battery, start car, check voltage at battery with Vom! You can do that?
    69
    82,383
    No, but todays cars have much more electronics in them than the old days and the battery (as MC pointed out) is an integral part of the electrical system as opposed to the old days when it was strictly used to start the car.
    Jul 2013
    41
    5
    Some braniac at O'Reilly's told me to do it. Yes, I will buy a voltomitor and test it. Thanks for your help.
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,323
    No need for a VOM. As posted, you have a voltage readout on your DIC.
  17. #15
    Jul 2013
    41
    5
    I went to O'Reilly's before I read your reply. I was told my voltage regulator failed. At this point I realize that I need to replace the
    alternator.
    Unfortunately, it got worse, as coolant came out of the overflow as he was checking the voltage. On my way home the cluster read HOT COOLANT.
    I stopped to let it cool down and then drove the remaining 2 miles home. At the very end it read ENGINE OVERHEAT.
    Did I just fu*k this car up?
    What else besides my radiator could cause the overheating?
    Thank you so much for assisting me.....all of you.
  18. Remove Advertisements
