No brake fluid, 97 DeVille - Page 2
Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 16 to 30 of 91
Like Tree17Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, No brake fluid, 97 DeVille in Past Cadillac Vehicle Discussion; Originally Posted by Ranger If you have a leak it should be obvious. You should see brake fluid at one ...
  1. #16
    AlcoholicProgram is offline Cadillac Owners Member
    Automobile(s): 1997 DeVille
    Jul 2013
    20
    94
    Re: No brake fluid, 97 DeVille
    If you have a leak it should be obvious. You should see brake fluid at one of the 4 brake calipers or one of the lines or connections.
    Do you know how to bleed brakes?
    Don't attempt to drive it.
    Went to NAPA today and they told me that to pour some in and find the leak, I had them take a look at it and they said I'll need to replace my brake lines before I do anything. I asked them about bleeding the brakes and putting new fluid in and they told me it would just all leak out within the day. (Of course I was skeptical of it at first but it does make sense)
    My father is going to take a look at it and see where we should go from there, maybe if I can find the problem I'll post up a photo or so for some recommendations on stopping it. We may just end up taking it in and having the lines replaced.
  2. #17
    68
    81,913
    All depends on where the leak is. DO NOT start replacing lines without knowing what is leaking. That could get VERY expensive real fast. Diagnose, then repair.
    AlcoholicProgram likes this.
  3. #18
    Jul 2013
    20
    94
    Hoping to drop off the car tomorrow at the mechanic for diagnosing. Only $45 for them to locate the problem in the brake lines and figure out what's wrong with my A/C Compressor, so I figured it was worth it. I'll report back on what they say.
  5. #19
    Jul 2013
    20
    94
    I discovered where the brake fluid is leaking, I went ahead and cancelled my appointment at the mechanic. If I post some photos maybe someone can help me identify what needs to be done to fix it? It seems it is leaking out underneath the engine, a little bit closer towards the cabin.
  6. #20
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    If you have a leak due to a rotted line, just do them all at once. I promise, it's worth it. When one blows, the others are right behind it, ALWAYS (the rest of them are just as rusty). Waiting for them to blow one by one is not worth the risk nor the headache.
  7. #21
    Jul 2013
    20
    94
    Quote Originally Posted by drewsdeville View Post
    If you have a leak due to a rotted line, just do them all at once. I promise, it's worth it. When one blows, the others are right behind it, ALWAYS. Waiting for them to blow one by one is not worth the risk nor the headache.
    Sounds pricey, yet worth it.
    Where can I get all the brake lines at? Seems like it would be cheaper to buy them all together, rather than separately..
  8. #22
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    They're not sold pre bent. It needs to be bought in bulk, along with fittings. Custom bent and flared.
  9. #23
    Oct 2004
    Oak Creek, WI
    5,609
    No one will make pre-bent lines for this car. If you need them replaced, the laborer will end up buying some brake line stock and they'll have to bend/flare the lines themselves. EDIT: as MC said.
  10. #24
    Jul 2013
    20
    94
    Ouch. Sounds even pricier! If I were to take it into a mechanic to replace them, can they (typically) replace all the lines?
  11. #25
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes. Parts are cheap, it's the labor that makes brake line replacement expensive.
  12. #26
    Jul 2013
    20
    94
    We've got a buddy who's going to weld me on a new muffler, and fix up my A/C, hopefully he'll do the brake lines at a discounted price.
  13. #27
    68
    81,913
    First check it out. It may not be a rusted line. Start looking at the master cylinder and then follow the brake lines from there.
  14. #28
    Jul 2013
    20
    94
    Gonna go take a look at it and see what I can find.
    If I were to replace the hoses on my own (with some help from a friend) how hard is it to do so?
    What all needs to be done when replacing them?
    EDIT: I just looked near the master cylinder and there is some hose sticking out from the engine with a metal cap(?) on it and it is just sitting there. Not sure what this has to do with or if I should even be concerned about this.
  15. #29
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,630
    That line with metal cap is vent for trans, leave it be.
  16. #30
    Jul 2013
    20
    94
    Quote Originally Posted by rodnok01 View Post
    Phew, I thought there was something else wrong with it. Thanks for clearing that up!
  17. Remove Advertisements
