Radiator fans not spinning/AC Issue on 97 DeVille - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 54 of 54
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Radiator fans not spinning/AC Issue on 97 DeVille in Past Cadillac Vehicle Discussion; Time to "tool up". Gauges R134A Pressures.jpg ac_diagnosis_chart.gif...
  1. #46
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    Re: Radiator fans not spinning/AC Issue on 97 DeVille
    Time to "tool up".
    Gauges
  2. #47
    AlcoholicProgram is offline Cadillac Owners Member
    Automobile(s): 1997 DeVille
    Jul 2013
    21
    94
    I've got a gauge for the low side, but not the high. I was making sure not to overcharge it, and the low side is really cold, as it should be, and the high is getting warm/hot, as it should be. The A/C is cold and running fine, I don't experience the sound normally, only when putting refrigerant in, and my A/C compressor even disengages at times when putting it in.
    I'm just gonna leave the A/C be, for now, I need to save my money to get my brakes working so I can get it back on the road. Once I do that, I'll respond back letting you know if I decide to get some real gauges for low/high, or just take it in to have a professional look at it.
  3. #48
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    -Problem is low side pressures just a few lbs of pressure apart can be drastically different on high side. You should be referencing a table of low/high pressures based on temp/humidity also. I picked a set of brass gauges off ebay for 50ish and they are very good quality.
  5. #49
    Jul 2013
    21
    94
    Quote Originally Posted by rodnok01 View Post
    Alright, I'm gonna get a set of gauges after I get my crucial components fixed.
  6. #50
    68
    82,082
    OK, I'm gonna say it now and hopefully you will remember it. NEVER EVER open the red high side valve unless the system is evacuated and you have it hooked up to a vacuum pump. Learn how to use then BEFORE you connect them. Having a set is one thing. Knowing how to use them is another.
    rodnok01 likes this.
  7. #51
    Jul 2013
    21
    94
    Thanks for that! I've used them before on a buddy's vehicle after we cleared the system and had it hooked up to the pump. Wasn't 100% sure if you had to do all of that before hooking it up to the high side. Thanks again!
  8. #52
    68
    82,082
    No it doesn't need to be evacuated to hook up to the high side. You just never open that valve. If you do, the can you have hooked up to the yellow hose becomes a grenade (with the pin pulled and the spoon released). Get the idea?
  9. #53
    Jul 2013
    21
    94
    I get it now. I'm young and still learning.. Sometimes you just have to make the point a little more obvious! Haha.
  10. #54
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,487
    AMEN to that -
  11. Remove Advertisements
