Radiator fans not spinning/AC Issue on 97 DeVille - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Radiator fans not spinning/AC Issue on 97 DeVille in Past Cadillac Vehicle Discussion; In the high pressure line going across the top? 54978256.jpg...
  1. #31
    AlcoholicProgram is offline Cadillac Owners Member
    Automobile(s): 1997 DeVille
    Jul 2013
    21
    94
    Re: Radiator fans not spinning/AC Issue on 97 DeVille
  2. #32
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    EZChill is for vehicles with R12 which you don't have.
  3. #33
    Jul 2013
    21
    94
    Quote Originally Posted by 13ir14314 View Post
    It says it works in R134a systems. I really only bought it to see if one of the adapters would fit on the vehicle as it seems my previous one was not wide enough. (Might need that new valve though)
  5. #34
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    Orifice tube;
  6. #35
    Jul 2013
    21
    94
    Okay, cool.
    Thanks for the help so far everyone, I'm going to try everything tomorrow, after I do it all I'm dropping it off at a mechanic shop to have my brake lines checked and they're checking the A/C system on top of it. I'll report back with everything they said on Wednesday or so.
  7. #36
    69
    82,180
    In order to get to the orifice tube you will have to open up the system to atmosphere. In order to recharge it you will have to pull a vacuum and to do that, you'll need a good set of gauges.
    P.S.
    If you find any debris on the orifice tube screen, that means that the compressor is failing, in which case you will need to replace the compressor, accumulator and condenser and flush the evaporator and all the lines.
  8. #37
    Jul 2013
    21
    94
    Well I just found out there was some o-ring stuck to the valve. Going to try and fill her on up with some refrigerant. I'll let you know what happens.
  9. #38
    Jul 2013
    21
    94
    Alright, I was able to get the refrigerant in the system and the A/C works great!
    Only one thing I noticed. Whenever I was putting refrigerant in the A/C Compressor was making a weird sound at times, sounded almost like clicking, or the sound a fan makes when you put paper through it (If you know what I mean), my dad said it's possible the compressor is still trying to run and get the refrigerant through (as it was completely empty previously) and is still trying to "warm" up. The sound doesn't happen whenever I leave the car running with A/C on, only when putting refrigerant in, and it's a very rare sound.
    Any ideas?
  10. #39
    Bugsy13ell is offline Cadillac Owners Member
    Jun 2013
    I am having this exact problem, although I did have a new engine put in my '96 Deville. And they did not hook up my A/C or Heater core. Would this affect the fans from cooling my engine?
  11. #40
    The Donald is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville delagance
    Apr 2012
    Colorado
    210
    A word to the wise.. If you dont know what you are doing or why, have a pro look at it you can really screw these systems up and it will cost much more to fix them then if you took it to a shop where knowledgeable people will do the job right. I take mine in once a year and have it serviced correctly, more damage is done by these cans of 134 then you would expect. Just my 2 cents.
    basscatt likes this.
  12. #41
    69
    82,180
    Quote Originally Posted by AlcoholicProgram View Post
    Any ideas?
    Compressors DO NOT need to "warm up" or try to get refrigerant through it. It either has enough refrigerant in the system or it doesn't. The clicking you hear may be the clutch engaging and disengaging. You may be low (or high) on refrigerant. How much did you add? What are your high and low side pressures. Adding refrigerant is not like adding gas. You DO NOT just fill it up. Refer to post #40. Did you open the system to check the orifice tube?
    Quote Originally Posted by Bugsy13ell View Post
    If your A/C is not running, the fans do not need to run unless the engine exceeds 224 degrees. They are auxiliary in nature when it comes to engine temperature, but run all the time when the A/C is on.
  13. #42
    Jul 2013
    21
    94
    As I do not have the proper tools, I let the orifice tube be. And I may be a little low, need probably one more can or so. But the clicking is not the clutch engaging and disengaging, I can confirm this. It's a different sound than that and when it happens it goes for a good 15 seconds or so.
  14. #43
    69
    82,180
    Remember, the system only holds about 2.2 lbs.
  15. #44
    Jul 2013
    21
    94
    Hmm.. I used almost all three cans (pulled the first off two early and ended up wasting some) which should put me at about 2lbs, maybe a little less. Think I should pick up another can and put in a little bit? (Each can of the EZ Chill is 12oz.)
  16. #45
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    You're on the road to dorking your AC up and killing the compressor...
    Those quicko cans are dangerous, they only give low pressure & that is not all the information you need to do it properly.
  17. Remove Advertisements
