Radiator fans not spinning/AC Issue on 97 DeVille - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 54
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Radiator fans not spinning/AC Issue on 97 DeVille in Past Cadillac Vehicle Discussion; That ain't good. I'd suspect a bad Schrader valve. The cap has an O ring in it also....
  1. #16
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
  2. #17
    AlcoholicProgram is offline Cadillac Owners Member
    Automobile(s): 1997 DeVille
    Jul 2013
    21
    94
    Re: Radiator fans not spinning/AC Issue on 97 DeVille
    Quote Originally Posted by rodnok01 View Post
    This thing?
  3. #18
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Might just be loose.. do you have a valve core tool?
    If it's tight already easy enough to change and cost 2-5 bucks at local parts place.
    Sometimes they get a piece of dirt in them, if you take a small screwdriver and give it a quick push/release it might stop leaking. If you do change it system will need to be vac down and refilled to do it properly and you'll need a set of gauges. Those cheapo can gauges just get you in trouble.
  5. #19
    Jul 2013
    21
    94
    I believe my dad has one of those in his toolbox, where is it located? Is it the valve that I put the refrigerant into?
  6. #20
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    If that's the valve spewing freon out then yes, the low side port.
    Please do no breathe the freon or get your hand frostbit if you change it out.
  7. #21
    Jul 2013
    21
    94
    Well I think I've found a problem, I've had this can of A/C Pro for awhile now and I believe it's "broken", because it will not connect to any of our other vehicles. We're gonna go run and get another bottle and see if that will connect to the car this time. Quick questions before I go: Should I only put refrigerant in while the compressor is on? (Since it turns on for brief moments and shuts right off). I know the engine needs to be run and you should have the A/C at Max. But, since it's turning on and off I am guessing I should only put it in while it turns on for those brief moments. Correct me if I'm wrong!
  8. #22
    68
    82,068
    Yes, you must have the A/C (compressor) on for the compressor to draw in the refrigerant, BUT you should not simply add a can. You really need a "set" of A/C gauges to see the low and high pressure readings. You might need a full can or you might only need a half of a can. If it's leaking from the service port, it's really irrelevant. It's gonna leak out anyway. That said, if it is leaking like you said, I am surprised you have any refrigerant left at all and that the compressor is not completely disabled.
  9. #23
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Don't think it will matter either way.
    I good set of gauges and can tap are only about 60 bucks online.
  10. #24
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    The AC Compressor and cooling fans are a circuit
    I have found that if the compressor OR fans are cut from the circuit, neither will operate
    Not sure about when the AC is in the off position tho... Never run mine without AC until the past few days when the fans failed... They were off and on for like a day and now nothing... Like the AC, Nothing
    I have a burnt plug but Was thinking a relay too...
    Jus throwing out my similar experience with this issue
    Who knows, maybe will help u look at things ?
  11. #25
    Jul 2013
    21
    94
    Picked up some refrigerant, tried the old AC Pro on my dads Tahoe and it snapped on right away. I picked up this EzChill stuff that came with a bunch of adapters. Maybe one of those will fit it for my coolant?
  12. #26
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Adapters? Did you buy a retrofit kit?
  13. #27
    Jul 2013
    21
    94
    Indeed I did.
  14. #28
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    Might be advantageous to pull the orifice tube before charging. Mine was clogged with metal shards.
  15. #29
    Jul 2013
    21
    94
    Quote Originally Posted by Jfarr View Post
    Where is the orifice tube located?
  16. #30
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Top line near firewall, you'll see a connection. If you change make sure to put in correct way.
  17. Remove Advertisements
