03 Deville passenger pre-sets acting funky.
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 03 Deville passenger pre-sets acting funky. in Past Cadillac Vehicle Discussion; Is it common for these cars (DHS/similar) to start acting up in terms of all the electronic presets for seat/steering ...
    redfishsc is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DHS
    Apr 2011
    153
    Is it common for these cars (DHS/similar) to start acting up in terms of all the electronic presets for seat/steering position, stereo settings, mirror position, etc?
    I've noticed that when I hit the keyfab to open the door, it readjusts everything to *almost* what it's supposed to. It really seems like it does a half-n-half of what it was previously set at, and what my presets are.
    Meaning, no matter how much I re-do the preset, it will never actually set the seats and steering (the main culprits) just to where I want them. I don't really care to fix it unless it's a simple "change this fuse", but I am curious about this. Normally, electronics are "go/no-go" instead of mashing up the data into seemingly random stuff.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Have you pulled your codes?
    Apr 2011
    153
    Re: 03 Deville passenger pre-sets acting funky.
    Yes.
    My ABS is out, so there's a few codes for that. My intake has a leak (parts coming) so I have a few "lean" codes. The only two codes I had that I didn't understand were AMP U1064, and IRC U1016. Losing communications with something, but I can't make out what it really means. These are "history" and not current codes.
    69
    82,386
    No problems with mine.
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    If something touches a control while it's doing the auto move to position, all motors will stop (including ones that wouldn't be affected by your control input.) Maybe something is brushing a switch?
    Apr 2011
    153
    Another interesting thing it does. Sometimes my wife uses her keyfab to open the door and get the kids strapped in their seats, and start the car. Thus, the presets are all hers.
    I will hit the "2" (my number) on the door side, and it adjusts everything, but the steering wheel and seat tend to do only about 2/3 or so of the movement. If I hit it again, everything moves "a little closer"
    but still not the right spot.
    It does NOT seem to worsen over time, so I'll consider this a "rich person problem" (despite being well below the median household income for our area lol) and just consider it an interesting inconvenience.
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    I had a very similar problem with my car when I got it but mine remembered the exact position that I set. Sometime I had to hold the number for everything to set and sometimes and had to push it a couple of times. After I replaced the battery it all work fine again.
    Mar 2011
    1,277
    Are you holding the button down until the motion completes? The motion will stop if you're in drive and pressing the button if you release it before the motion is complete. (It should run to completiong without holding if the car is in park/noone in the seat... (I'm not sure of the exact conditions.))
  11. Remove Advertisements
