Coolant dripping down flywheel housing (pics included)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Coolant dripping down flywheel housing (pics included) in Past Cadillac Vehicle Discussion; Hello everyone -- Car: 2002 Deville Quick background: - check coolant light came on, topped off surge tank for awhile ...
    Farmer is offline Cadillac Owners Member
    Automobile(s): 2002 Deville Northstar
    Jul 2012
    11
    Hello everyone --
    Car: 2002 Deville
    Quick background:
    - check coolant light came on, topped off surge tank for awhile and all was well -- left the car sit for a few days and noticed a puddle of coolant about dead center of engine
    -Got a pressure tester and started to look around for any leaks and found the coolant dripping off the bolts in the picture below
    The part in the above picture is #13 in the picture below FYI
    I'm not very familiar with Devilles so any insight would be appreciated. I am going to get back under the car tomorrow and see if I can find anything out, hopefully someone recognizes this problem and can steer me in the right direction.
    Thank you
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    544
    Re: Coolant dripping down flywheel housing (pics included)
    I'm thinking a leak at the crossover may run down at that point.
    68
    81,916
    Yup. 2000+ engines seem to have crossover manifold gasket failures for some reason. Thankfully, mine failed while still under warranty. Not a fun job.
    Jul 2012
    11
    Quote Originally Posted by bigtone View Post
    Thanks for the quick replies! I'm glad to have an idea what the problem is, although it looks to be a pain!
    I found this thread http://www.cadillacforums.com/forums...-pictures.html and hope that will save some time/headaches.
    Anything else I should look into replacing while tackling this job?
    Thanks!
    68
    81,916
    That should pretty much do it. Just be sure it is not a hose. It would suck big time to do this job for nothing.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    absolutely pinpoint where that leak is coming from before touching a single bolt -
    Jul 2012
    11
    I'm still hunting for the source. It looks like the leak is coming from around the area in the first photo. I've got the pressure at ~18-20 PSI and I haven't noticed any coolant on hoses other areas, just in the picture below. Thoughts?? Thanks!
    The leak is right around this area (hard to definitively tell because it's so damn cramped under there)
    Pic to provide a little reference
    Jul 2012
    11
    Pics to come...noticed a bad clamp that was allowing a small leak. Going to investigate around the water pump
    Jul 2012
    11
    Jul 2012
    11
    This the coolant crossover????
    What's up with the sharpie marker on it? Replaced part?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes, that's part of the crossover.
    No clue on the marks.
    68
    81,916
    The crossover manifold aka W/P housing is #371.
    http://www.gmpartsgiant.com/Page_Pro...PartSortBy=Key
    Jul 2012
    11
    Great - thank you very much!
    On a positive note it appears the water pump cover is the updated one (w/ tabs) and is in good shape.
  16. #14
    Jul 2012
    11
    Update
    I have found this thread to be rather helpful! And as I've said before -- thank you guys for your input!! It's absolutely unreal the value of internet forums.
  17. #15
    btg1976 is offline Cadillac Owners Member
    Automobile(s): 2001 Deville DTS
    Mar 2013
    6
    I had exact same issue. Top gasket on firewall side of crossover was leaking. If you do find this to be your issue do yourself a favor and try to tighten crossover bolts around the gasket that's leaking. In my case I was able to tighten almost a half turn when cold and an additional quarter when hot. This resolved my leak!
  18. Remove Advertisements
