Coolant Steam coming thru AC dash vent - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 89
Like Tree24Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Coolant Steam coming thru AC dash vent in Past Cadillac Vehicle Discussion; Originally Posted by MoistCabbage Hose clamps. They're included. Ok Thanks Sent from AutoGuide.com Free App...
  1. #16
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Hose clamps.
    They're included.
    Ok
    Thanks
  2. #17
    Aug 2012
    Tampa Florida
    38
    854
    Ok
    So I bypassed the heater core and everything seems fine
    AC seems colder, hmmmm???
    The coolant got up to 235* tho but I think the driver side cooling fan went out again bc it took about 30minutes to creep up there and it was up and down (228*/235*) with stop n go traffic
    Checked coolant level about an hour after I got to work , had a lil pressure still when i took off the cap and was still full so I'm guessing no serious leak
    SUPER LAC DEVILLE
  3. #18
    69
    82,383
    Re: Coolant Steam coming thru AC dash vent
    235 is a tad high. Keep an eye on it.
  5. #19
    Aug 2012
    Tampa Florida
    38
    854
    So I jus cranked it up
    Turned AC on high and popped the hood
    5 mins , No fans at all
    Played with the wires lil bit and the driver side flipped on high then low then off then back on
    The other is dead
    Gonna order new ones asap
  6. #20
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    If one fan runs when you fool with the wires, what makes you think new fans will behave any differently ?? It's time for a thorough wiring, connector, and relay check BEFORE spending $200 or so on new fans/motors.
  7. #21
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by Submariner409 View Post
    Have no idea why I didn't think of that 1st but I will do that now
    SUPER LAC DEVILLE
  8. #22
    Feb 2006
    57,139
    Here's your wiring diagram. Right click it, save as, and save it to a temp file or flash drive, zoom it out and print it. (Use a real computer - not some dinky smart phone app - can you even print from a cell phone ?)
  9. #23
    Aug 2012
    Tampa Florida
    38
    854
    Thanks Sub
    And yes u can print from most any iOS or Android phone thru wifi or Bluetooth if the device/printer has those options, most do
    With my iPhone, I can actually save the photo and zoom, minimize, cut, crop, enhance, Print on your Unlocked Printer if its in range etc . And that's with the iPhones basic features... No apps
    SUPER LAC DEVILLE
  10. #24
    Feb 2006
    57,139
    Good to know ............. My OLD (ancient) Nokia makes/receives calls and that's about it. Karen and I together use less than 15 minutes a month of cell time.............. I actually use a bit more in the STS OnStar system - 16 minutes last month.
    SUPER LAC DEVILLE likes this.
  11. #25
    Aug 2012
    Tampa Florida
    38
    854
    Ok...
    So the passenger side fan plug/connector looks burnt
    I cleaned it as best i could but its obviously been cooking (shorting out) for some time
    I repositioned and tie strapped it to the metal post between the two fans so that it gets current and Both fans come on
    So now, do I replace the plug (how) or do I replace the whole passenger fan???
  12. #26
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    Ok...
    well - you have diagnosed the problem as a bad plug -
    so I would plan on just replacing the burned up plug -
    HOW?
    couple choices -
    go to the boneyard - locate a similar car - cut off the electrical plug you need -
    cut off your screwed up plug - splice in the other good used plug -
    OR -
    go to rockauto.com - put in your car information -
    go down the parts list to - and CLICK on
    Electrical-Connector
    go down Electrical-connector parts list to - and CLICK on
    Radiator Fan Motor Connector
    choose the one that looks like the one you need -
    you need to solder the wires - and cover them with shrink-tubing -
  13. #27
    Aug 2012
    Tampa Florida
    38
    854
    Ah
    For now,
    I shall replace the plug
    I've decided to order some new cooling fans tho
    I noticed the passenger one is consumed by rust and the fan wobbles as it gets up to speed
    The other one took most of the impact from that accident I was in last year... Surprised it still worked and still to this day but ill feel more comfortable retiring the two and installing new plugs and fans
    They've done there job long enough and I can't risk anymore damage to my engine
    When i checked for codes I noticed i had the PCM P1258 code (protection mode active) which i believe is the Camel Mode ... and it did get me down the street and across the intersection at 15/20mph after the heater core blew out
    I can sure attest to its ability to keep the car moving... ... tho, I didn't drive it more than a mile...
    Anyways
    I wanna thank y'all for the help and direction on fixing the Super Lac Deville
    I was feeling like my best friend was about to die in the hospital and y'all gave me hope with each response
    Thanks so much everyone
    SUPER LAC DEVILLE
  14. #28
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    find a set of good used fans - to save money
  15. #29
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by basscatt View Post
    I was actually thinking saving money on these and maybe buying some good ones when I get my income tax refund
    http://bit.ly/1btynGI
  16. #30
    69
    82,383
    The plug is burnt because the blower is drawing too much resistance and over heating the plug. Bottom line is the blower is on it's way out. I'd replace both the blower and the plug. Otherwise you'll have to replace the plug again later when the blower finally goes. Pay me now or pay me later, your choice.
  17. Remove Advertisements
