Break in for brakes
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Break in for brakes in Past Cadillac Vehicle Discussion; While I got my tires rotated for free, I got my brakes checked for free at the tire shop today. ...
    CadillacLuke24's Avatar
    CadillacLuke24 is online now Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Forever West
    26
    5,772
    Break in for brakes
    While I got my tires rotated for free, I got my brakes checked for free at the tire shop today. As I figured, the pads are toast. The rotors, unfortunately, wouldn't have much of any life left, so it's time for new pads and rotors.
    My question is whether or not there is a break in period I should follow to ensure maximum component life. The owner's manual says 500 miles for factory equipment. Should I follow that, or is there something else I should reference? Thanks guys
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,162
    Re: Break in for brakes
    Read the brake pad/rotor manufacturer's recommendations for proper break-in.
    Depending on the rotor, pad composition, and pad type there are different methods of proper break-in. You can do it in an intense 2 hours of rural driving or you can let nature take its course and drive the car in an urban environment for a week or so.
    69
    82,386
    Personally, I never break in or bed new brakes, at least not intentionally. I just install 'em and use 'em.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by Submariner409
    ^^This^^.
    SuperMidget is offline Cadillac Owners Member
    Automobile(s): 1995 base Deville
    Jul 2012
    34
    35
    i ran the front desk of an auto shop for a while dealing with customers and whatnot.... i was always told by the old school mechanics to try and not do any hard panic type stops for 100 miles or so with new brakes and everything should be fine
    69
    82,386
    Funny, that is the exact opposite of GM's (and I think most brake pad manufacturers) bedding procedure. Honestly, I think you'd be OK either way.
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    744
    Basically pads need to be "baked". Most of the more expensive higher quality pads are already. The cheaper less expensive pads need to be done by the installer or driver, by making several stops with a bit of cooling between them.
    Jul 2010
    Forever West
    26
    5,772
    Thanks guys. If there is instructions with the new ones, then I will go off those. If not, I will follow the procedure defined in the owner's manual. I will also give the FSM a look see.
    Feb 2006
    57,162
    CadillacLuke24 likes this.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    Why do you think you need new rotors?
    Rotors don't wear out like pads. They usually only need replaced when damaged. (like when the pads are completely gone )
    I usually buy high quality pads, install them, then drive it.
    Jul 2010
    Forever West
    26
    5,772
    Quote Originally Posted by bigm57ict View Post
    They measured the rotors. They are tenths of millimeters from discard specs as listed in the FSM. Figured better to replace them now and be safe than try and use them and be sorry.
    Feb 2006
    57,162
    Yep ^^^^ EVERY brake rotor has a go/no go discard thickness specification. It is illegal - federal - for any shop to re-use rotors that are out of spec.
    If a truing cut or skim will place the rotor thickness at discard spec it cannot be re-used.
    69
    82,386
    Agreed. If they are that close, replace them.
  16. #14
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    65
    347
    I would do some homework and first decide on what type of pads you want. Some pads (i.e., ceramic) will produce less (or virtually no) brake dust, but they may have less stopping power (for EVERYDAY street use) than others ('organic', for instance). I was suffering from lack of stopping power on my DeVille and my Chevy pickup. I did some research and ended up replacing ceramic pads with EBC "Green Stuff" pads on both vehicles, and I noticed a huge improvement in stopping power. EBC included very specific bedding instructions with their pads.
    Here's a nice one-page article from Hot Rod magazine that talks about brakes and bedding: http://www.hotrod.com/techarticles/c...y/viewall.html
    Additionally, there are tons of good articles at the page that Submariner409 posted: http://ebcbrakes.com/technical-articles/
  17. #15
    Sep 2010
    East Boston MA.
    29
    26,323
    Both sub and I have RedStuff pads, and I think I can speak for both of us, that we're very happy with them in all aspects.
  18. Remove Advertisements
