1996 DeVille VIN Y new suspension
Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1996 DeVille VIN Y new suspension in Past Cadillac Vehicle Discussion; My DeVille has roughly 76,500 miles. I have determined I need new struts for the front, as well as springs ...
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,759
    I have determined I need new struts for the front, as well as springs and sway bar links.
    I have determined the need exists because:
    A-My car bounces like a basketball after going over a bump. ESPECIALLY the front end. There is more movement than there was when I first acquired the old girl.
    B- My left side is lower than the right. I notice it from outside the car, and it is clearly evident inside the car.
    C-I've heard clunks from the front, and I've read that the links are often a culprit
    D- Can you say BODY ROLL?
    I have selected the following parts to remedy the situation:
    MONROE KIT #90008-Convert from active to passive struts, cause I ain't made of money.
    Sway bar links from cadillac bushings.com
    Delco springs
    I am not sure if the tie rod ends are bad. Steering is fine, no noticeable issues. What I have noticed is that there is a vibration when braking, especially after aggressive maneuvering (such as a run through the twisties). There are passing vibrations at highway speeds, but these are nearly undetectable. New tie rod end time?
    Since all four corners have the same mileage on them, to the best of my knowledge, the rear will be getting serviced as well.
    MONROE Part#40046
    Delco Springs
    I have a while before I plan of servicing the aforementioned parts, so I figured I'd sample your guys' knowledge to make sure I have the right ideas. Thanks for your help
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Re: 1996 DeVille VIN Y new suspension
    Your 96 Deville does not have active struts. Shop passive struts.
    Jul 2010
    Wyoming
    26
    5,759
    Quote Originally Posted by maeng9981 View Post
    I thought all the 96 struts were active, and in 97 the base DeVilles were converted to passive. My FSM even says the shocks are adjusted via a computer controlled solenoid
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    Isn't 96 the one off year for active struts, only fit 96? Do believe was only available with active from factory. Pretty sure that's why I avoided that year.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    front struts -
    Monroe 90008 - $203.32 for the kit - with free shipping -
    http://www.amazon.com/Monroe-90008-S...ype=automotive
    MOOG 81086 front springs - $58.00 - for the pair - free shipping -
    http://www.amazon.com/Moog-81086-Coi.../dp/B002VJYAQS
    front sway bar links -
    Mevotech MK5319 - $10.54 each - +$6 shipping = $16.54 each
    http://www.amazon.com/dp/B001NZSMLA
    THESE ARE ACTUALLY EXCELLENT QUALITY PARTS -
    AND THIS IS A GREAT PRICE -
    rear shocks -
    Monroe 40046 - $110.56 each - free shipping -
    http://www.amazon.com/gp/product/B0047D9TS0/?ie=UTF8&
    me=ATVPDKIKX0DER
    rear springs -
    MOOG 81005 - $81.66 for the pair - free shipping -
    http://www.amazon.com/Moog-81005-Fro.../dp/B00180DVIO
    CadillacLuke24 likes this.
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    rear monroe 40046 @ rockauto was 106.00 for each then add shipping so overall probably same price, just make sure u get an air line kit, if u cannot use old
    Jul 2010
    Wyoming
    26
    5,759
    Thanks guys! I knew basscatt would set me straight on any errors I might have made.
    Any opinions on the tie rod ends?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    Quote Originally Posted by CadillacLuke24 View Post
    might as well replace them -
    outers -
    MEVOTECH Part # MES3238RL - $27.20 - for both - with shipping -
    from rockauto.com -
    Jul 2010
    Wyoming
    26
    5,759
    Works for me. And then I will have mah tire shop align everything when it's all said and done.
    Thanks bass. Gee, with all the help I've solicited from you in the past month or so, I think I should cut ya a check!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    PayPal would also work -
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    didn't know that about 96's. Learn something new every day.
    Jul 2010
    Wyoming
    26
    5,759
    No kidding. This noob here thought steam from a bad heater core was a sign of HG failure
    dusty256 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 sedan deville
    Feb 2013
    62
    188
    Does that part number include everything but the springs . Mounts etc .
  16. #14
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Which part number?
  17. #15
    Jul 2010
    Wyoming
    26
    5,759
    Quote Originally Posted by dusty256 View Post
    Monroe kit 90008 does include everything strut related (mounts etc.). Springs are NOT part of the package and will need to be purchased separately.
  18. Remove Advertisements
