Results 1 to 11 of 11
Thread: 92 deville shuts off while driving with ac on
    kzback is offline Cadillac Owners Member
    Automobile(s): 1992 deville
    Jul 2013
    5
    while driving coasting and turning my deville shuts off only when ac is on any suggestions would help.
    thanks
    69
    82,286
    Re: 92 deville shuts off while driving with ac on
    Failed or misadjusted ISC motor? What is your normal idle speed? Does the ISC motor plunger extend and engage the throttle linkage when you turn the ignition on?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
  5. #4
    Jul 2013
    5
    im not sure what that is but i do notice the gas pedal sort of moves a little by itself while driving
  6. #5
    69
    82,286
    The ISC motor (#80) is the small motor next to the TB with the plunger that extends to push on the throttle linkage (at idle only). It would not affect the throttle while driving unless you are off the throttle and decelerating.
  7. #6
    Jul 2013
    5
    Ok, will it make the car seem like its on cruise cont, cause thats when i feel the pedal moving while letting up on pedal or coasting
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes, it's called "sail on" when that happens.
  9. #8
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Any codes? Could be a bad P/S.
    You did mention it happens while turing not sure how often the power steering switches go out.
    Try to recreate the problem with A/C and without A/C.
  10. #9
    Jul 2013
    5
    only happens with ac on, while coasting or if im doing any type of accelerating it keeps running
  11. #10
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Post #2 has the solution. It should be easy to find a thread with the adjustment procedure because there is over 1000 threads on that very subject.
  12. #11
    Jul 2013
    5
    thanks
  • You may not post replies
