Electronic Level Control malfunctioning
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Electronic Level Control malfunctioning in Past Cadillac Vehicle Discussion; I have a 2004 deville with 155k. Lately i've been noticing that when i start the car the ELC comes ...
    Bthomas is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Deville
    Jun 2012
    North East Colorado
    3
    I have a 2004 deville with 155k. Lately i've been noticing that when i start the car the ELC comes on and the car levels out. However, whenever i stop, be it a stop light or whatever, the rear of my car jumps like the ELC is engaging again. This will happen multiple times at a red light or when the car is idling. Could i have a bad sensor and how serious is this problem?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Define "jumps". The ELC system can't inflate the air bladders very quickly at all.
    69
    82,383
    Re: Electronic Level Control malfunctioning
    I would suspect a leak in one of the air lines. Spray them with soapy water with the compressor running and look for foam.
    Jun 2012
    North East Colorado
    3
    The rear of the car jerks upward, almost like its been hit from behind(though not very hard). Its very noticeable and very quick. I'll be at a stop light for 25 seconds or so and all of a sudden the rear of the car jerks up And this will happen quite often.
    The compressor comes on for about 30 seconds when i start the car. Is that when i need to check the air lines or is there a way to keep the compressor running?
    Sep 2010
    East Boston MA.
    29
    26,323
    The "jump" is definitely not the ELC system, possibly a sticking shock?
    Does the compressor come on whole driving or stopped, other than when you start the car.
    Jun 2012
    North East Colorado
    3
    I never thought of that but it makes sense. I just went out and started the car. Compressor came on and the car leveled out. I let it idle for 5-10min and nothing happened. I then put it in drive and let it sit and again nothing happened. The roads here in town are absolutely atrocious for any car so it makes sense that one of the shocks might be sticking. Is there a way to fix that or is replacing them the better option?
    Sep 2010
    East Boston MA.
    29
    26,323
    You'd have to replace them. If you bounce the car up and down, does it move smoothly? Does it bounce a couple if times and stop, or keep bouncing?
  10. Remove Advertisements
