2002 deville trunk lid leak help
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2002 deville trunk lid leak help in Past Cadillac Vehicle Discussion; Hi, I have an 02 deville with a trunk lid leak. I can't pin point exactly where its coming from. ...
    ssramos is offline Cadillac Owners Member
    Automobile(s): 02 deville
    Jan 2012
    1
    Hi,
    I have an 02 deville with a trunk lid leak. I can't pin point exactly where its coming from. On heavy rain days, when I open the trunk I see the water leaks from in between the trunk lid and lid liner. On some days water comes from the right side of the latch, and other times it leaks from both. The water doesn't leak into the trunk. It just gets puddled up inside the lid liner. This only happens with heavy rain.
    Has anyone encountered this before or might have tips or a solution to this issue?
    Thanks in advance.
    69
    82,383
    Re: 2002 deville trunk lid leak help
    Probably the perimeter gasket.
