Stabilizer Bar Bushings
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Stabilizer Bar Bushings in Past Cadillac Vehicle Discussion; Next project, chasing the squeak to the stabilizer (sway) bar. Does one need to remove the sway bar and slide ...
    Goldencletus is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille Concours, 2004 Nissan 350Z Roadster
    Feb 2013
    Gold Country of California
    60
    109
    Next project, chasing the squeak to the stabilizer (sway) bar. Does one need to remove the sway bar and slide new bushings over the bar, or are the bushings two piece that can be installed with the bar in place? I've looked at the online auto parts suppliers and can't tell from the pictures. They also have many different bushing diameters listed for my car. I would have thought that the sway bar would be a universal size for all 1998 Deville Councours. I guess I'll measure to be sure prior to ordering. Thanks in advance for the help!
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Re: Stabilizer Bar Bushings
    There are 2 different sized bars on deville's, so yes measure first.
    They do slide onto the bar(one piece EOM anyways). I had on side bracket off on drivers side to check the bushing and it was too hard, not much room I needed a racheting box wrench.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    Both deville and concours are supposed to use the same bushing for that year. The ones you get from GM are one piece with a slit in it so so you can pop it on over the bar.
    Feb 2013
    60
    109
    Thanks, that's what I was hoping for!
    Jun 2003
    Canada
    6,449
    You're welcome. Be ready for a lot of wrenching, the bolts that hold the brackets on are long.
  8. Remove Advertisements
