01 deville drivers rear wheel bearing replacement.
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 01 deville drivers rear wheel bearing replacement. in Past Cadillac Vehicle Discussion; Is there a good video out there on how to replace the rear drivers hub? I saw a video on ...
    devillin's Avatar
    devillin is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    52
    29
    Is there a good video out there on how to replace the rear drivers hub? I saw a video on a Buick that I believe is similar.
    I think its pretty simple after you remove the rotor, some bolts and it pops off.
    Ranger is online now Cadillac Owners Member
    68
    82,049
    Re: 01 deville drivers rear wheel bearing replacement.
    I am sure there is a youtube video somewhere (there is for everything else), but it is pretty straight forward (same as the Buick).
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    What makes you think the hub bearing is bad?
    This says the 2001 is different than what I wrench on.
    http://www.cadillacforums.com/forums...e-bushing.html
    There are good pictures.
    devillin's Avatar
    Oct 2008
    52
    29
    I hear and feel a crunching from the rear while in motion. I removed the wheels and found no noises while I spun the wheel by hand, not loose either. I'm sure the weight of the car has to be on it.
  7. Remove Advertisements
