03 DTS leaking from sunroof!
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 03 DTS leaking from sunroof! in Past Cadillac Vehicle Discussion; I got in my car this morning and found a puddle of water on the driver side floor!! I believe ...
    Robp is offline Cadillac Owners Member
    Automobile(s): 2003 DTS
    Jul 2012
    San Antonio, TX
    34
    40
    I got in my car this morning and found a puddle of water on the driver side floor!! I believe it is leaking from my sunfroof is that a possibility! Any feed back would be appreciated! Thanks in advance.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    65
    347
    Re: 03 DTS leaking from sunroof!
    Likely a clogged drain. Be careful when trying to clear. Mine was leaking and I used air blower, but there is some danger of blowing hose off, so be careful. I think some guys recommend gently running a small wire down through.
    I got lucky on mine. The compressed air fixed the problem..............
    Jul 2012
    San Antonio, TX
    34
    40
    Thanks I will try the hanger first! Do you happen to know the length of the line or lines
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    29
    538
    When mine did that 2 years ago took to dealer they only charged $40 to clear drains
    Mojo88's Avatar
    Dec 2011
    Newport, RI
    65
    347
    Quote Originally Posted by Robp View Post
    NOOOOOO! Don't put a hanger down there. You'll tear something for sure.
    Take something with a thin spray nozzle (like WD40) and give it a little shot in each drain. You should be able to tell which one is plugged. Then run a piece of thin, flexible wire down gently through the plugged drain.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    I use string trimmer line.
    Ranger is online now Cadillac Owners Member
    69
    82,386
    .080 weed wacker line. NO coat hangars!
    Jul 2012
    San Antonio, TX
    34
    40
    Thanks guys!! I will use some of the weed eater line I have some that gauge I think!!
    elmysterio is offline Cadillac Owners Member
    Automobile(s): 2003 cadillac dts
    Apr 2012
    45
    also check and make sure your ac drain is not clogged
  12. Remove Advertisements
